Topics48,340
Posts812,974
Members9,203
Posts: 502 |
I've just installed some new clear indicator lenses to the rear of my morgan as for some reason the previous owner had only replaced the front ones with clear lenses. I was in wilkos earlier today and saw some orange bulbs so got them prior to installing them. However, as can be seen from the below image, the bayonet lugs are off centre. I've went onto wilkos website and seen an image of a clear bulb, also with the same off centre lugs. I can't see the why such a thing should be in existsnce. Surely that would mean it might sit off centre when installed. Needless to say, it wouldn't fit properly, so luckily I had some spares. ![[Linked Image]](https://www.tm-img.com/images/2022/03/17/DSC_0438.jpg)
2004 Series 1 Roadster
Posts: 181 Likes: 1
Posts: 181 Likes: 1 |
It's done so a clear bulb cannot be put into a holder that has an orange lens which has been changed to clear. I had the same problem but the correct orange bulbs are available.
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 26,747 Likes: 419
Posts: 26,747 Likes: 419 |
I bought mine from classic car LEDs they do both sorts as orange bulbs.
Posts: 6,056 Likes: 160
Posts: 6,056 Likes: 160 |
Yep - when a manufacturer uses orange bulbs/clear lens, they usually have offset pins to prevent people putting clear bulbs behind a clear lens.
If you are converting orange lens indicators to clear lens you need to find orange bulbs with opposite pins. I use 'chrome' bulbs - they are silver in appearance but light up orange - it avoids the 'fried egg' look.
Amber Offset Bulbs usually have the code 581, Amber Straight Bulbs are 382.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 502 |
Well that does make sense. Yes, the code 581 is on the packaging. Best get some spares ordered. Much prefer the clear lens look. Thanks guys!
Posts: 7,920 Likes: 216
Posts: 7,920 Likes: 216 |
There are many bayonet car bulb base variants, see here. Single filament with the common 15mm base are BA15s or 382 and dual filament (stop/tail) bulbs BAY15d or 380 on most Classic Mogs. Obviously the wattage has to be correct for purpose as well in the case of filament bulbs. An alternate to orange filament indicator bulbs are no hyperflash amber LED's which won't affect the flash rate. ETA: note that 581 type although single filament have radially offfset pins so won't fit. You need 382 type as above.
Posts: 502 |
Think I'll order from the place Richard and John suggest. Guess with them being LED, they'll last longer.
Yep those are the ones. They are excellent.
Posts: 5,107 Likes: 56
Black Rat Charter Member
Posts: 5,107 Likes: 56 |
I fitted clear lenses to the front only I thought clear lenses on the rear looked odd.
Posts: 502 |
Yep those are the ones. They are excellent. Bought some. Pricey, but if it means I have to change them less its a bonus as those little brass connectors that keep getting pushed into the base plate are annoying 😂
