7 members (gomog, GLLOQ, John V6, Barkbark, JohnHarris, BLUE+4, AlyMatt),
329
94
Topics49,877
Posts837,727
Posts: 28,906 Likes: 353
Posts: 28,906 Likes: 353 |
Forward the un-edited version to
report@phishing.gov.uk
Every time i try this it tells me the mailbox is full! Must be a lot of scammers around. Never had that and I seem to report a lot of scams
Posts: 8,686 Likes: 493
Posts: 8,686 Likes: 493 |
Never had it fail for me, and whilst we're discussing these things don't forget 7726 on your mobile to forward those scam texts, the network blocks 'em and can even disable the scrote's mobile remotely
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
Every time i try this it tells me the mailbox is full! Must be a lot of scammers around. Your address is probably on a black list of spammers  (joke)
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Never had it fail for me, and whilst we're discussing these things don't forget 7726 on your mobile to forward those scam texts, the network blocks 'em and can even disable the scrote's mobile remotely The problem with fraudulent SMSs and calls, or even telemarketing calls, is Caller ID Spoofing; that is send fake caller ID phone numbers. If you try to call back you get a message telling you that the number does not exist. I don' t know about the UK but here it makes it a waste of time blocking a number because the bar---ds keep changing the numbers they use. If ever you have wondered why you get calls that stop after a few rings or hang up without response it is because they have a robot caller looking for numbers that are not in use so that they can be used for Caller ID Spoofing. In an even nastier way Caller ID Spoofing can be used to fake in real numbers for fraudulent reasons.
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
Your address is probably on a black list of spammers  (joke) Metric or Imperial?
Posts: 5,466 Likes: 171
Posts: 5,466 Likes: 171 |
I don't understand why networks cannot eliminate caller ID spoofing. Here in the UK, BT claim that they will be able to do it when they roll out the next generation network over the next few years. It should be straightforward. The network allows caller ID creation in support of large corporates using VOIP services with local break out to the PSTN. It should be easy to create a register of legitimate users of this service and bar all others.
