8 members (RichardV6, Graham, G4FUJ, Davetherave, John Winn, MartinB60, John V6, nick w, Morganmike), 259 guests, and 60 robots.
+8Rich 69
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,716
MOG 615 #736490 18/03/22 01:24 PM
Originally Posted by MOG 615
Forward the un-edited version to
report@phishing.gov.uk
Every time i try this it tells me the mailbox is full! Must be a lot of scammers around.
Never had that and I seem to report a lot of scams smile
Never had it fail for me, and whilst we're discussing these things don't forget 7726 on your mobile to forward those scam texts, the network blocks 'em and can even disable the scrote's mobile remotely
MOG 615 #736524 18/03/22 04:08 PM
Smile, it confuses them
Your address is probably on a black list of spammers wink oops
(joke)
CooperMan #736531 18/03/22 04:29 PM
The problem with fraudulent SMSs and calls, or even telemarketing calls, is Caller ID Spoofing; that is send fake caller ID phone numbers. If you try to call back you get a message telling you that the number does not exist. I don' t know about the UK but here it makes it a waste of time blocking a number because the bar---ds keep changing the numbers they use.
If ever you have wondered why you get calls that stop after a few rings or hang up without response it is because they have a robot caller looking for numbers that are not in use so that they can be used for Caller ID Spoofing.
In an even nastier way Caller ID Spoofing can be used to fake in real numbers for fraudulent reasons.
Alistair #736543 18/03/22 06:25 PM
(joke)
Metric or Imperial?
Best Regards
Lang may yer lum reek
Gambalunga #736547 18/03/22 06:47 PM
I don't understand why networks cannot eliminate caller ID spoofing. Here in the UK, BT claim that they will be able to do it when they roll out the next generation network over the next few years.
It should be straightforward. The network allows caller ID creation in support of large corporates using VOIP services with local break out to the PSTN. It should be easy to create a register of legitimate users of this service and bar all others.
Costock, UK
Disco 5
