6 members (bmgermany, Ian Wegg, John Winn, DCH, RichardV6, Graham, G4FUJ), 321 guests, and 88 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Page 3 of 3 1 2 3
In that case it's most likely the sprocket. In any case you'll shortly need to change it to a steel sprocket or have the Supermax conversion.
Red Leader drive
Okay I will post here again. I am pretty sure this noise is coming from the front. I am going to guess that the tight corner (steering wheel nearly locked) at speed causes this noise due to either fender rubbing on tire or bearings giving up due to rust. I will let everyone know what I find. I think I can test for bearing by jacking up left front and seeing if there is play in the wheel.
end user
If there is wear/play relating to your front wheel I suspect there may be no need to jack it up, just grab the top of the wheel and give it a good shake, if the bearing is worn you will likely hear a clunk, likewise if wear in wear in the suspension it too may clunk. For wear in the steering grab the front and rear of the wheel push on one hand while pulling with the other and reverse the process a few times..
Best of luck Craig..
Bonjour, j ai eu un problème similaire avec la mienne la direction était bizarre et faisait du bruit quand je faisais allé le volant de gauche à droite .
Ça c est terminé par le deboitement de la rotule de direction inférieur gauche. Heureusement c est arrivé en la rentrant au garage et pas en sur la route
If your tyre is rubbing you should be able to see a mark left on the rubber.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Page 3 of 3 1 2 3
