2 members (jim109b, linklaw),
296
Posts837,990
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
Librands do a couple of brackets which allow you to re-position the number plate box below the front apron. Effectively covers the bottom of Simon's alloy rad - without any restriction of airflow. ^^^ The first modification I made when I bought the car, not to hide the radiator but to show the chrome at the bottom of the grill. When I do need to replace the plastic radiator with one of Simon's aluminium ones it'll be covered and protected though. ![[Linked Image]](https://www.tm-img.com/images/2022/03/24/IMG-20180224-WA0001__01.jpg)
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Posts: 488 Likes: 27
Posts: 488 Likes: 27 |
Thanks for the tip Gordon
And thanks for the link Dave. I would normally install something like this on my own but time at the moment is hard to come by so I'm having Williams install it. But thank you again.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Librands do a couple of brackets which allow you to re-position the number plate box below the front apron. Effectively covers the bottom of Simon's alloy rad - without any restriction of airflow. ^^^ The first modification I made when I bought the car, not to hide the radiator but to show the chrome at the bottom of the grill. When I do need to replace the plastic radiator with one of Simon's aluminium ones it'll be covered and protected though. ![[Linked Image]](https://www.tm-img.com/images/2022/03/24/IMG-20180224-WA0001__01.jpg) That looks good Gordon, I lowered mine only slightly with home made brackets. I did have it lower than this but it looked slightly odd with the front valance. ![[Linked Image]](https://tm-img.com/images/2021/04/28/B6FE9D6D-DED5-4D72-A0BB-3E53580C484D.jpg) ![[Linked Image]](https://tm-img.com/images/2021/04/27/B4757048-CD6D-4FBC-86F6-7E42C5CAB2F3.jpg)
Craig Jezz
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
I've been in contact with Simon and have a shorty arriving in time for my service. SImon informed me that the shorter version is still 15% bigger than the factory fit version so was happy to go with that. Great choice Perry. Welcome to the “shorty club”  ![[Linked Image]](https://dl.dropboxusercontent.com/s/2qgelxunv28om5w/shorty.jpg)
Roger 2011 Plus 4
Posts: 2,519 Likes: 320
miles of smiles Talk Morgan Expert
Posts: 2,519 Likes: 320 |
One thing’s for sure your car, although almost identical to look at, must feel very different to mine now, I’ve hardly changed a thing. I did have a coolant smell a while back but it was a minuscule amount , so much so I didn’t see the coolant level drop at all. I narrowed it down to the hose clip at the reservoir which needed to be tightened almost to death.
