0 members (), 241 guests, and 47 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,148
Page 19 of 21 1 2 17 18 19 20 21
All suggestions please. I started the job and have fallen at the first hurdle. Can’t remove nut to get the fuel filter out cos it moves so far then just spins. I can feel the nut on the back spinning but can’t get at it to unscrew properly.
Is this a remove the back seat job? If yes I can see the four bolts that need to be removed. Once removed is it then free at is something else holding it?
2021 Morgan Plus Four
2012 Morgan Three Wheeler
2020 Land Rover Defender 110
You shouldn't need to remove the fuel filter, there is a clamping strap around it with one screw top left of this picture.
You just need to slacken the filter clamp so that the filter will slide away from the fuel pump to allow the two fuel hoses to be released from the top of the fuel pump. Ignore the push tab to release caption as it is the other end of the hose you need to release.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Hello Rog - if only mine were that simple. The band around it is screwed top and bottom to a metal plate to the rear of the seat. There is no such screw anywhere along the band. Not to worry I managed to unscrew the top one now after many hours of struggling. I'll get there
Well I finally did it. Now at 58psi instead of the 50psi before the job. Started almost immediately unlike the previous 3 months. Test drive tomorrow morning so fingers crossed it's all sorted now.
Thank you all for the help along the way
Bunny Offline OP
That's great news - Well done!
Andy
Hi, I am looking at upgrading my fuel pump and like to research and know what to do before I get there, so my first question is about the black plastic 2 part cover, does this come off in one go together or does it need separating to remove, mine looks to be siliconed together but looks to be loose from anything else ie no other silicone sealing it to the body
It needs to be separated into the two parts. Use a blade to cut through the silicone. You can then remove the smaller part first, the larger part on some cars can be a bit fiddly as the flange can get trapped by the wooden frame.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
I don't know if you have these instructions but they are very good:
https://www.mtwc.co.uk/wp-content/u...l-pump-replacement-April-2020-update.pdf
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
That’s a great help thanks, I do have the instructions but this part wasn’t clear to me, thanks
Thanks to Ian Brett & Andrew Warren for the excellent instructions. Just replaced my Fuel pump.
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
