Topics49,838
Posts837,294
Posts: 263 Likes: 2
Posts: 263 Likes: 2 |
All suggestions please. I started the job and have fallen at the first hurdle. Can’t remove nut to get the fuel filter out cos it moves so far then just spins. I can feel the nut on the back spinning but can’t get at it to unscrew properly.
Is this a remove the back seat job? If yes I can see the four bolts that need to be removed. Once removed is it then free at is something else holding it?
2021 Morgan Plus Four 2012 Morgan Three Wheeler 2020 Land Rover Defender 110
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
You shouldn't need to remove the fuel filter, there is a clamping strap around it with one screw top left of this picture. ![[Linked Image]](https://www.tm-img.com/images/2018/02/20/IMG_1844.jpg) You just need to slacken the filter clamp so that the filter will slide away from the fuel pump to allow the two fuel hoses to be released from the top of the fuel pump. Ignore the push tab to release caption as it is the other end of the hose you need to release.
Posts: 263 Likes: 2
Hello Rog - if only mine were that simple. The band around it is screwed top and bottom to a metal plate to the rear of the seat. There is no such screw anywhere along the band. Not to worry I managed to unscrew the top one now after many hours of struggling. I'll get there
Posts: 263 Likes: 2
Well I finally did it. Now at 58psi instead of the 50psi before the job. Started almost immediately unlike the previous 3 months. Test drive tomorrow morning so fingers crossed it's all sorted now.
Thank you all for the help along the way
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
That's great news - Well done!
Andy
Posts: 62 |
Hi, I am looking at upgrading my fuel pump and like to research and know what to do before I get there, so my first question is about the black plastic 2 part cover, does this come off in one go together or does it need separating to remove, mine looks to be siliconed together but looks to be loose from anything else ie no other silicone sealing it to the body
Hi, I am looking at upgrading my fuel pump and like to research and know what to do before I get there, so my first question is about the black plastic 2 part cover, does this come off in one go together or does it need separating to remove, mine looks to be siliconed together but looks to be loose from anything else ie no other silicone sealing it to the body It needs to be separated into the two parts. Use a blade to cut through the silicone. You can then remove the smaller part first, the larger part on some cars can be a bit fiddly as the flange can get trapped by the wooden frame.
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Hi, I am looking at upgrading my fuel pump and like to research and know what to do before I get there, so my first question is about the black plastic 2 part cover, does this come off in one go together or does it need separating to remove, mine looks to be siliconed together but looks to be loose from anything else ie no other silicone sealing it to the body I don't know if you have these instructions but they are very good: https://www.mtwc.co.uk/wp-content/u...l-pump-replacement-April-2020-update.pdf
Posts: 62 |
That’s a great help thanks, I do have the instructions but this part wasn’t clear to me, thanks
Posts: 423 Likes: 2
Posts: 423 Likes: 2 |
Thanks to Ian Brett & Andrew Warren for the excellent instructions. Just replaced my Fuel pump.
Lance 1981 Plus 8 2016 Three Wheeler 2022 Corvette Stingray Convertible z51
