Topics49,911
Posts838,147
Posts: 3,735 Likes: 80
Posts: 3,735 Likes: 80 |
After my "bafflectomy", cat removal and S&S stealth air filter installation the standard ECU did not allow big enough adjustment to allow the engine run well on both low ang high rpm´s.
I changed the ECU to the S&S VFI Module Kit 55-5090 from Delphi and had a local tuner fine-tune the standard mapping. The engine now is running better then ever. As far as I understand this ECU is still available? The S&S ECU is made by Delphi and loaded with a M3W specific tuning map. If the blank ECU is still available then loading a M3W map with Protune should work. From my old EU3 locked ECU: ![[Linked Image]](https://www.tm-img.com/images/2021/05/25/20210525_124845.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/05/25/20210525_124920.jpg)
Red Leader
Posts: 107 |
I do not have Protune or the skills to do the tuning myself so I did get help from a local custom motorcycle workshop. If I understand this correctly they read in a M3W map in the new unlocked ECU and then did the tuning of fuel/airmix that was not working before. With Protune you can live-tune so you get the response directly in the engine while testing. Interestingly they did the tuning driving on real roads as the could not get the M3W on their rolling road. I bought the ECU from the motorcycle shop but here is a link to a US company selling the ECU: https://vtwin.parts/supplier/ss-cyc...cycle-ss-cycle-ss-vfi-module-kit-55-5090
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Dang, they've gone up in price quite a bit since I bought mine in 2018. But it looks like it might be a newer specification.
Steve Late 2012 M3W
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Dang, they've gone up in price quite a bit since I bought mine in 2018. But it looks like it might be a newer specification. Did you buy one to eliminate the locked aspect?
Yes. Wanted the ability to merge maps and not lose any current (non-merged) adaptive maps when I disconnect power, which I do whenever it's parked in the garage.
With a locked ECU, anytime you disconnect the battery you lose the adaptive maps which are created each time you drive. So your car goes back to the factory baseline. Which is not a big deal unless you have modified something, like air cleaner, exhaust, or cams. Once at baseline it will take many miles of driving in varying conditions to get the ECU back to it's happy place.
Steve Late 2012 M3W
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
Does anyone have a download link for the ProTune 2 software? It does not seem to be available in the 'Tech Info' section of the www.sscycle.com website any more.
Andy
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Does anyone have a download link for the ProTune 2 software? It does not seem to be available in the 'Tech Info' section of the www.sscycle.com website any more.  Hi Andy, I have a PDF copy of the Pro-Tune II manual. Can send it to you if you PM me with your address.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
Does anyone have a download link for the ProTune 2 software? It does not seem to be available in the 'Tech Info' section of the www.sscycle.com website any more.  The link on this page still seems to work. https://www.sscycle.com/racing/support
Thanks Rog, that seems to have worked.
Andy
