3 members (Image, TBM, Fuel.inj), 260 guests, and 66 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,427
Ian S, thanks for converting the link to display the pic. Being a Luddite, while I did eventually come to understand which of the options from the list might display any pic I might be posting at the time of posting... However once a pic is already in an album, I failed to find an option available that was obvious to my admittedly limited attention span/patience... given I would no doubt forget the process in time and thinking that if there was any "real" interest in seeing the pic then clicking the link might be no issue... Whatever, though thanks again for making things simpler Ian. thumbs
BTW, one other aspect that may be of interest is that Kevin`s design was such that there was still good rearward visibility, though for some that may require an adjustment of the mirror positioning which is a simple matter with the rod mounted internal mirror, but perhaps less so if one has a mirror base glued to the screen..?
RichardV6 #739073 15/04/22 06:40 PM
Originally Posted by Deejay
Good value, agreed. But...try lifting it when it’s full...maybe why they are often advertised as “little used”?
Try lifting it when it's empty! wink
How about this one? I don't use it but it came with the car.
I might use it as a coffee table in my man cave. thumbs
Dirk
1993 Morgan +4 (Connaught Green)
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
DirkM #739076 15/04/22 07:43 PM
Looks seriously heavy, you coud get a body in there ! crazy2
My thought exactly!
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
My thought exactly!
The German word for suitcase is Koffer and that seems very appropriate here - it's massive..
The perfect solution for heavy steering smile
The racks I think are designed for 25kg loads. That case alone looks that heavy.
Another bootbag fan here. Holds plenty and not too high.
+8Rich #739229 17/04/22 04:46 PM
My thought exactly!
The Dutch word is also koffer.
Dirk
2009 Mini Cooper D
2024 Mercedes GLC
1994 Ford Motorhome
