10 members (Simon, GrumpyPa, TalkMorgan, Gordon D, Craig Jezz, TBM, scortroadster, chanteclair, SteveT, DPEvans),
402
132
Topics49,859
Posts837,479
Posts: 5,442 Likes: 468
Posts: 5,442 Likes: 468 |
Ian S, thanks for converting the link to display the pic. Being a Luddite, while I did eventually come to understand which of the options from the list might display any pic I might be posting at the time of posting... However once a pic is already in an album, I failed to find an option available that was obvious to my admittedly limited attention span/patience... given I would no doubt forget the process in time and thinking that if there was any "real" interest in seeing the pic then clicking the link might be no issue... Whatever, though thanks again for making things simpler Ian.  BTW, one other aspect that may be of interest is that Kevin`s design was such that there was still good rearward visibility, though for some that may require an adjustment of the mirror positioning which is a simple matter with the rod mounted internal mirror, but perhaps less so if one has a mirror base glued to the screen..?
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
Posts: 537 Likes: 28
Posts: 537 Likes: 28 |
Good value, agreed. But...try lifting it when it’s full...maybe why they are often advertised as “little used”? Try lifting it when it's empty!  How about this one? I don't use it but it came with the car. I might use it as a coffee table in my man cave.  ![[Linked Image]](https://live.staticflickr.com/8537/29190912980_7ab48a1869_c.jpg)
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2024 Mercedes GLC 1994 Ford Motorhome
Posts: 1,984 Likes: 103
Posts: 1,984 Likes: 103 |
Looks seriously heavy, you coud get a body in there !
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
Posts: 185 Likes: 2
Posts: 185 Likes: 2 |
Looks seriously heavy, you coud get a body in there !  My thought exactly!
2005 Plus 4 2020 Hyundai eKona 2020 Mitsubishi Outlander PHEV
Posts: 37,416 Likes: 977
Posts: 37,416 Likes: 977 |
Looks seriously heavy, you coud get a body in there !  My thought exactly! The German word for suitcase is Koffer and that seems very appropriate here - it's massive..
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
The perfect solution for heavy steering
The racks I think are designed for 25kg loads. That case alone looks that heavy.
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Another bootbag fan here. Holds plenty and not too high.
Looks seriously heavy, you coud get a body in there !  My thought exactly! The German word for suitcase is Koffer and that seems very appropriate here - it's massive.. The Dutch word is also koffer.
Dirk
