7 members (DaveW, cerealsurfer, PaulJ, teknome, Graham, G4FUJ, TBM, Ritchie B), 107 guests, and 111 robots.
+8Rich 78
Topics49,872
Posts837,695
Rudolf
#739340 18/04/22 06:55 PM
GLLOQ Offline OP
My speedometer had been working sporadically for years and no longer worked after three repairs to the sensor harness, so I ordered a sensor from China and on a $12 promotion to try to repair it, I was billed $150 the last time in Malvern. So I ordered with aliexpress a sensor for HD with Delphi direct plug it also comes with cable harness and Deutsch three-pin connector, the original sensor is wired with a 1w - 2k ohm resistor perhaps to lower the strength of the signal. The problem that I may encounter again is pain on the side of my stomach caused by my wife who nudges me while watching the speedometer as I drive, the last time she did not dare on the highway because she not sure what 6200rpm is in fifth gear when accelerating.
https://fr.aliexpress.com/item/1005...=a2g0o.order_list.0.0.6f245e5bTdmq6C_the center distance and the diameter may be smaller, the length is identical, which is why I rebuilt a support, it is possible to fix it in the same place by drilling another tapped hole.
.[Linked Image]
Thanks for that !
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Good one for the Alternate Parts List. Thank you.
Great info GLLOQ , many thanks
What type of air filter are you using. Looks a simple solution.
GLLOQ Offline OP
With my sensor, you have to choose the black three-way Delphi connector.
to mount the air filter, the part must be made to measure.
have-your-driven-you-m3w-today-stories?/page 220
GLLOQ Offline OP
The electrical connection with the Delphi connector is: A red yellow wire B yellow pink C yellow black and I put a 1w - 2k ohm 5% resistor between yellow red and yellow pink, you have to choose the black Delphi connector which is different from the connector Grey.
If you choose a sensor with wires I think the connection is black with yellow black red with yellow red white with yellow pink, to be tested.
Nice job again
