Morgan Aero 8
2 members (Gordon D, B3MOG), 88 guests, and 62 robots.
+8Rich 76
Topics49,861
Posts837,531
Jonny72
#740076 25/04/22 12:40 PM
Neilda Offline OP
In a rare appearance (I have it on SORN until next month) my 8 is off to HQ for a pre-Provence shake down. Collected by MMC ...and away....
Primarily to sort a fuelling issue (it takes too much time and the delicacy of a surgeon to get any petrol into it) and to have a service and MOT. It's the first time it's been back to the factory since I had it built.
Neilda #740078 25/04/22 12:47 PM
Formerly known as Aldermog
An interesting car straightjacket....or cocoon!
Will they return it, or do you plan to collect it?
Neilda #740082 25/04/22 01:56 PM
Neilda Offline OP
They'll bring it back when it's done.
+8 4.8
Neilda #740092 25/04/22 03:38 PM
I'd be concerned about the hold-down belt buckles possibly contacting the front wing. frown
Is their some type of protective padding for them? confused2
Bert & B1800
Neilda #740109 25/04/22 06:50 PM
Interested in the solution for the fuelling issue
Neilda #740131 25/04/22 10:55 PM
There's a Factory fix for the refuelling issue, about 90 minutes labour. Mine was sorted. I can't understand why the dealers weren't told of the mods 🤔
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Neilda #740141 26/04/22 05:51 AM
PJC Offline
I thought it was "Just me" that hadn't quite used my Aero enough to have mastered the "Knack" of what angle and depth to hold the pump in order to get fuel in to the car - clearly not. Any hints/tips gratefully received by me and others by the sound of it.
Cheers, Paul
BertL #740143 26/04/22 06:37 AM
Neilda Offline OP
The metal buckle simply needs to be folded back inwards before being rested on the wing. It's a non-issue. I rarely need to open the bonnet, but this technique of fold back the buckle is simple. [Edit: I misunderstood, you mean the hold downs on the trailer. smile I think they slot into place on the side rails]
What was the solution Taffmog to your refuelling issue? Do you know what the factory fix was?
I will update when it comes back, but I understand there is a filler cap with more holes for air to escape which stops the problem. I hope so as it's my only real criticism - I hate filling it as it takes ages and I never really know how much fuel has been delivered.
+8 4.8
Neilda #740166 26/04/22 10:46 AM
Smile, it confuses them
When the Coupe was first delivered it suffered from some issues that made my brain sag.
Terrible filling speed and blow back.
Swingometer grade accuracy of the gauge.
Both did end up getting fixed on one of it's trips back to the factory.
The filling speed was related to the "o'clock" location of the breather holes you could see in the facing. They needed to be at the top and the pipes connected to them needed an untwisted run. Once this was done the filling speed and consistency improved greatly.
Neilda #740173 26/04/22 01:22 PM
PJC Offline
Hi Alistair, I've had a look at my fuel filler and the once the lockable cap is removed sprung cover hinges at the 12 o'clock position and folds downwards and back towards the front of the car. The breather hole is at 9 o'clock and is uncovered during the process of depressing the main spun filler cover. Am I missing anything / is there a particular ideal angle for the fuel nozzle to go in at the aids the "Breathing" and prevent the continual auto-stopping of the fuel from the pump?
Cheers, Paul
