3 members (mph, Graham, G4FUJ, Alan Patterson), 175 guests, and 74 robots.
Topics49,848
Posts837,395
DazMog, The Impaler, tlchzj79
#740200 26/04/22 04:42 PM
SMHM Offline OP
Hello everybody
fortunately my wife wants to drive the 3W, and since she is small I have to make the pedals move. Otherwise I am the one not fitting the car anymore ....
Has anybody tried something like this sliding pedal box base?
If so please advise, many thanks Stefan
3Gs Offline
Here is that pic for easy reference...
How do you access the release mechanism to move it from the cockpit?
PMB Offline
Hello
Sounds interesting... How about a seat sliding console?
https://shop.gperformance.eu/product/sparco-seat-slider/
Depending on that, I would change the left and right consoles so that the lever would be on the outside. Then you could lower the pedals again so they would be almost at the original height... So order a console, have new sheet metal bent for the pedals and bend a new lever... The lever could go through in front of the tube frame so it doesn't interfere... Haven't been to the garage yet and looked at the footwell, just as a thought...
PMB Offline
it's nice when your wife wants to drive the Morgan... Then you have a good reason to get a 2nd Morgan 😅😍
SMHM Offline OP
Exactly! How comes you know my arguments? That's why after 35 years my Plus 8 is not alone any more ....
SMHM Offline OP
The AP one has a cable operated release mechanism, which will unlock the slider and allow you to pull it towards you. But it may be prohibitively costly
SMHM Offline OP
Hello
Smart idea, many thanks. Will check how that would work given limited space. Both sides locking seems perfect. Maybe this one here is too wide, but the handle can be easily modified. Will keep you posted
Thank you.
Hello Stefan
This was our solution: https://www.speedymarmots.com/works-3-the-back-cushion-for-am/
I don't know if it will work for your wife. As a reference, I am 1,82 m tall, and Ana Maria is 1,64 m.
