9 members (Ncik P, Soleng, DCH, eds, Ritchie B, DaveW, Luddite, Mike D, TalkMorgan),
305
36
Topics49,837
Posts837,286
Posts: 159 Likes: 1
Posts: 159 Likes: 1 |
Does someone know where I can get the hardware to put on a bonnet strap ?
1980 + 8
Dutch Junge 194 Mound St Logan, OH USA 43138
2012 3 Wheeler 1980 + 8
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
1980 + 8 As far as I'm aware there isn't any hardware required. You just put the end of the belt between the wing and the little buffer jobbie that sits between the two bonnet catches. Obvs you'd need to drill a hole in the end of the belt to bolt through. I can't illustrate that bit because my bonnet belt is at the bottom of a box at the back of the garage. ![[Linked Image]](https://tm-img.com/images/2022/05/06/Screenshot-2022-05-06-at-17.46.51.png)
Best mod I made to my 4/4 was taking out the knackered old 87bhp CVH engine and putting in a tuned 165bhp GM Ecotec VVTi. Or to be more accurate, paying Kevin Vernon to do it for me. Other than that I've been particularly pleased with:
- Fitting hard chrome kingpins - SSL Front suspension - Quaife ATB 4.1:1 Diff - Simmonds hood - My 3D printed coin tray and water bottle holder - Additional LED brake light strip mounted to rear luggage rack - Tool tray under rear shelf - Twin piston billet front brake callipers and reaction bars - Panhard rod and anti-tramp bars
Modifications which upon reflection were a waste of time and have now been discarded:
- Wind wings - Subwoofer behind the driver's seat - removing the damper blades and fitting a telescopic damper
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
Mine ('75 crossflow 4/4) has two little strap loops that bolt through the wing .... not yet fitted my bonnet strap and assumed the strap looped round them and fastened back on itself .... now thinking that they are just a guide to feed the strap under the bonnet snug to the wing and it then bolts to the rubber snubber bracket as described above . Bit of a light-bulb moment as I wasn't looking forward to sewing through the nice stout leather straps I'd got 🙂👍
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
Best three mods to my '92 plus4
Audible alarm on the indicators. Mulfab brake up grade Adding clock
John 1992 plus4 connaught green
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
On my 3.7l Roadster 1. Gps speedo. The speedo reads 10% low and is off to the left 2. K&n air filter 3. LED headlights 4. Cruise control 5. Beeper for indicators 6. LED indicator and other bulbs
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
1980 + 8 I hope this picture helps ![[Linked Image]](https://tm-img.com/images/2022/05/06/F57E5FB3-EA1A-4CF7-9A7C-8C788FFFCAC7.jpg)
Craig Jezz
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Best modifications:
Brakereaction bars, a massive step forward. Hoodstay (homemade) Raising up the seats Homemade tooltray Homemade dash with maplight Fitting twoeared spinners
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
Best of most recent mods:
5 speed gearbox Stainless Tank Electric fuel pump (makes starting much easier)
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
- Grease gun holder box under the bonnet - Sat nav mounting bracket - Givi pannier mounting kit on luggage rack - Rod mirror (easy up hood) - Bonnet props
