Topics49,849
Posts837,411
Posts: 135 |
For some time the central pin on my 1990 +8 driver's door lock has been loose meaning the door doesn't shut tight. I finally got round to removing it from the 'pillar' to see if I could tighten it. I assumed it had a nut on the back, forum users may be interested in the design. I'm guessing the door locks and catches are originally Land Rover Defender? Fortunately I have speakers fitted so I was able to remove the speaker and gain access behind the frame to remove the nuts on the 2 retaining bolts. I also removed the cup screws down the front edge of the trim panel and could spring the panel open to gain access. It turned out the pin is fixed to the plate with a couple of tack welds on the back and these had fractured. I ground off the broken welds and cadmium plating locally and my mate applied 3 new welds. I didn't take a picture of the broken welds but here is the repair: https://tm-img.com/image/Fnz6Uhttps://tm-img.com/image/FnLPs[/
1990 +8 Connaught Green 1970 Lotus Elan S4 SE 1973 Lotus Europa TC/Special
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
![[Linked Image]](https://tm-img.com/images/2022/05/13/IMG_0491.jpg) Doubt you will have any further trouble with this repair
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
![[Linked Image]](https://tm-img.com/images/2022/05/13/IMG_0489.jpg) This is the other photo
Posts: 135 |
Thanks for doing the photos gents, it always defeats me on this forum, much harder than most!
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
As I see now, an usual problem… http://www.talkmorgan.com/ubbthreads.php/topics/736544/1And a lot of possibilities to repair. Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
