3 members (BGW, John Winn, nick w),
175
62
Topics49,846
Posts837,382
Posts: 3,847 Likes: 400
Posts: 3,847 Likes: 400 |
Changed my tyres and 3 of the 4 are ok however the one has gone flat over night, going back for the spare to have a new tyre fitted today (only had 4 in stock) and they will remount the tyre again. Any obvious things to look for or possible solutions? It does have stainless wire wheels fitted.
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
Did they damage the silicone seal around the spokes?
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Either the valve or the silicone seal.
Richard V6 posted on how he fixed the seal.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
The tyres on my 4/4 have always had inner tubes. Was this a standard fit? Bud 4/4 - Stanley
Bud 4/4 "Stanley"
Thanks for the input, spoke with the tyre fitter and they have something that might fix the sealant issue if its that. Will find out at 3pm. I hope its an easy solution..........
Posts: 8,666 Likes: 408
Posts: 8,666 Likes: 408 |
Richard V6 posted on how he fixed the seal. If they have tubeless tyres JohnHarris I would put money on the fitters having damaged seal on one wheel. I managed to damage the seal on two of mine by simply taking up a ΒΌ turn of slack on a spoke on each, so can verify the seal (formed with sealant) is very fragile if mistreated. This also makes it easy to repair minor damage though using correct sealant available from MWS who supply OE wheels to MMC. See thread here. Pic below of seal with damaged part dug out ready to receive fresh sealant. ![[Linked Image]](https://i.imgur.com/Uv7N21t.jpeg)
Thanks Richard for that, I hope its just the valve. Clearly a whole lot of hassle if its the black sealant..........dont you just love wire wheels.
Kind regards
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
The Roadster wires are wide, and having watched the fitter change mine, it's very easy for the tyre bead to scrape the sealant. All four of mine were slightly damaged, despite the fitter being experienced and an old friend. But I don't take the Morgan for tyre changes, I take the wheels off. Just in case.
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
Just the same happened to me. In spite of several attempts it kept leaking. New silicone, new rubber band inside the rim - you name it - did not help. We even detected the very spoke that was reponsible for the leak, but to no avail. So I ended up putting a tube into the tyre, problem solved. Now I run on three tubeless tyres, and the fourth with a tube. I would have preferred tubeless all around, but I can live with this. As for handling and comfort, I do not notice any difference.
Robbie the Norseman 2004 V6 Roadster Sherwood green
