1 members (ScotiaSteve), 301 guests, and 103 robots.
+8Rich 84
Topics49,860
Posts837,484
#741778 13/05/22 09:08 AM
CJB Offline OP
For some time the central pin on my 1990 +8 driver's door lock has been loose meaning the door doesn't shut tight. I finally got round to removing it from the 'pillar' to see if I could tighten it. I assumed it had a nut on the back, forum users may be interested in the design. I'm guessing the door locks and catches are originally Land Rover Defender?
Fortunately I have speakers fitted so I was able to remove the speaker and gain access behind the frame to remove the nuts on the 2 retaining bolts. I also removed the cup screws down the front edge of the trim panel and could spring the panel open to gain access.
It turned out the pin is fixed to the plate with a couple of tack welds on the back and these had fractured.
I ground off the broken welds and cadmium plating locally and my mate applied 3 new welds.
I didn't take a picture of the broken welds but here is the repair:
https://tm-img.com/image/Fnz6U
https://tm-img.com/image/FnLPs[/
1990 +8 Connaught Green
1970 Lotus Elan S4 SE
1973 Lotus Europa TC/Special
CJB #741795 13/05/22 01:34 PM
Doubt you will have any further trouble with this repair thumbs
CJB #741797 13/05/22 01:45 PM
This is the other photo
CJB #741816 13/05/22 04:27 PM
CJB Offline OP
Thanks for doing the photos gents, it always defeats me on this forum, much harder than most!
CJB #741818 13/05/22 04:29 PM
No worries
CJB #742492 21/05/22 02:37 PM
X
X
As I see now, an usual problem…
http://www.talkmorgan.com/ubbthreads.php/topics/736544/1
And a lot of possibilities to repair.
Greets René
2018 plus4 (sports green)
