2 members (Taffmog, DaveK),
216
Topics49,911
Posts838,148
Posts: 159 Likes: 1
Posts: 159 Likes: 1 |
I've got a 1980 + 8 The horn is not working so I'd like to track down the horn and see if it's getting power. If it is and no honk I've got a horn that I can hook up and test. But I don't know where the horn is located. I haven't hunted too hard but I haven't seen it yet.
So where is it ?
Dutch Junge 194 Mound St Logan, OH USA 43138
2012 3 Wheeler 1980 + 8
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Below and behind the grille, usually, just ahead of the bottom of the radiator.
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Dutch, according to the wiring diagram covering a 1980 +8 there were two horns. The wiring was unconventional though having the horn push switch a live, fused feed, so beware if you need to investigate in this area. There should then be purple/black cables feeding each horn with the other terminals locally grounded.
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
I have had a few fail. They are easy to replace. As Graham says the horns are on the cowl box just in front of the radiator.
Posts: 14,750 Likes: 158
Posts: 14,750 Likes: 158 |
The location of the horns is not ideal. I had the experience of hitting deep standing water in a railway underpass at about 50 kph. It was like driving under a waterfall with all the water spraying up over the car. I was most impressed that no water came into the car (hood up because of the storm). What I did discover, after a few kilometres, was that my brand new pair of FIAMM horns emitted only a water sodden gurgle. They never fully recovered and I returned to the original single horn plus a matching second horn from the same manufacturer. . I have fitted them in such a way that they don't act as water scoops
Posts: 832 Likes: 23
Posts: 832 Likes: 23 |
On my 1980 I binned the original, well it fell off and subsequently added a discreet air horn in its place
1980 +8 Blue And a few others ---------------- Stephen
Posts: 159 Likes: 1
Thanks for all the info. I'll start checking everything out this week.
Posts: 159 Likes: 1
My son and I found the horn and yes it was dead. I had a Vespa horn laying around that I took off of the GTV when I had it. Hooked it up and it worked so we replaced the Morgan horn. Just had to make up a ground wire. Works just fine. Got a little toot now. :-)
