9 members (MartO, Davetherave, DickJ, Image, Luddite, RichardV6, BLUE+4, JohnHarris, BobtheTrain),
320
66
Topics49,877
Posts837,717
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
My spare wheel cover panel has torx (star head) screws holding it in place for which you need a special driver bit to fit/remove. Do you have the chaffing problem as well?
David 2020 Roadster 3.7 Dove Grey.
Posts: 543 Likes: 2
Posts: 543 Likes: 2 |
I only fitted it in March and it hasn't been off yet!
Posts: 27,820 Likes: 749
Posts: 27,820 Likes: 749 |
Posts: 88 |
The main thing is not to overwritten the holding screws. I do them finger tight only - this does mean you need to keep an eye on them 'cause the buggers will get loose after a long drive. Morgan actually resprayed the rear panel for me last September and fitted a slightly thicker seal. I removed the panel a couple of weeks ago, all was well so I waxed the paintwork then cleaned and applied some Vaseline to the seal before replacing.
