6 members (Graham, G4FUJ, John Winn, MartinB60, John V6, nick w, Morganmike), 242 guests, and 55 robots.
+8Rich 69
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,877
Posts837,716
Originally Posted by paulmog
My spare wheel cover panel has torx (star head) screws holding it in place for which you need a special driver bit to fit/remove.
Do you have the chaffing problem as well?
David
2020 Roadster 3.7 Dove Grey.
I only fitted it in March and it hasn't been off yet!
You will
The main thing is not to overwritten the holding screws. I do them finger tight only - this does mean you need to keep an eye on them 'cause the buggers will get loose after a long drive.
Morgan actually resprayed the rear panel for me last September and fitted a slightly thicker seal.
I removed the panel a couple of weeks ago, all was well so I waxed the paintwork then cleaned and applied some Vaseline to the seal before replacing.
