6 members (Dinko, B3MOG, Strathaven, TalkMorgan, RichardV6, Graham, G4FUJ), 279 guests, and 25 robots.
+8Rich 99
John V6 55
Topics49,908
Posts838,110
#744337 12/06/22 02:36 AM
NelsonG Offline OP
Hello all,
As my front end rebuild is drawing to a close, it was time to rebuild my front brakes. All stripped, cleaned, new seals, pistons, O-rings, painted (blue caliper paint on inside, G2 black on outside).
Does anyone know the correct torque values for the bolts that connect the caliper halves on a set of Girling 14s? I saw a video on YT rebuilding a pair of Girling 16s and the guy said he was taught the outer 9/16 bolts get 40 ft-lbs, and the the inner 5/8 bolts get 70 ft-lbs.
Seemed reasonable so that’s what I did. But advice from anyone who’s done this would be appreciated.
Also, any suggestions on how much to torque the brake lines going into the calipers? I’ve put on fresh copper crush washers.
Thanks.
-Nelson
- Nelson
1966 Plus 4 RHD
NelsonG Offline OP
Found another reference for the 40/70 recommendation: Caliper Restoration
Found an error in my post, the outer bolts are 3/8” (takes a 9/16 AF spanner) and the outer bolts are 7/16 (takes a 5/8AF spanner).
Any ideas on how tight to torque the brake lines?
- Nelson
1966 Plus 4 RHD
