Topics49,848
Posts837,408
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
As advised, we fitted a slimline sump and raised the ride height by c.10mm at the front to give 30mm extra clearance. But we are still grounding on speed bumps. How far is it safe to raise the height further without adversely affecting things?
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
If you hit a pothole you can sue the council for damage. Does the same apply to speed bumps?
SFG 2012 4/4 Sport
Posts: 2,087 Likes: 70
Posts: 2,087 Likes: 70 |
If you hit a pothole you can sue the council for damage. Does the same apply to speed bumps? Depends how high the speed bump is. Maximum is 100mm or 4 inches.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
And they should be painted and have clear warning signs
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
As advised, we fitted a slimline sump and raised the ride height by c.10mm at the front to give 30mm extra clearance. But we are still grounding on speed bumps. How far is it safe to raise the height further without adversely affecting things? I spaced my engine mountings and got another 7mm from memory.
Are you sure it is the sump hitting? With my S1 fitted with a mulfab sump & standard front end what grounded was the chassis cross member under the gearbox.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Are you sure it is the sump hitting? With my S1 fitted with a mulfab sump & standard front end what grounded was the chassis cross member under the gearbox. Me too
Are you sure it is the sump hitting? With my S1 fitted with a mulfab sump & standard front end what grounded was the chassis cross member under the gearbox. I have just tried it on a number of speed bumps and the rear of the new sump and the crossmember ground together. I am sure that others must have experienced this.
Very odd. Mine never did.
Posts: 3 |
I have a fabricated steel one in production from Mulfab as we speak with side wings for extra capacity. You seem a little bitter regarding Mulfab as when you left working there with Peter you set up in competition with his ideas . Competition is a good thing but it’s time you concentrated on your business and stopped bitching about there’s
