3 members (BGW, John Winn, nick w), 175 guests, and 62 robots.
Topics49,846
Posts837,382
Page 3 of 7 1 2 3 4 5 6 7
M3W55 #747316 08/07/22 03:47 PM
M3W55 Offline OP
As advised, we fitted a slimline sump and raised the ride height by c.10mm at the front to give 30mm extra clearance. But we are still grounding on speed bumps. How far is it safe to raise the height further without adversely affecting things?
M3W55 #747318 08/07/22 04:01 PM
SFG Offline
If you hit a pothole you can sue the council for damage. Does the same apply to speed bumps?
SFG
2012 4/4 Sport
SFG #747320 08/07/22 05:23 PM
Depends how high the speed bump is. Maximum is 100mm or 4 inches.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
M3W55 #747325 08/07/22 06:14 PM
And they should be painted and have clear warning signs
M3W55 #747327 08/07/22 07:02 PM
I spaced my engine mountings and got another 7mm from memory.
M3W55 #747358 09/07/22 08:29 AM
Are you sure it is the sump hitting? With my S1 fitted with a mulfab sump & standard front end what grounded was the chassis cross member under the gearbox.
Me too
M3W55 Offline OP
I have just tried it on a number of speed bumps and the rear of the new sump and the crossmember ground together. I am sure that others must have experienced this.
M3W55 #748059 15/07/22 07:15 AM
Very odd. Mine never did.
I have a fabricated steel one in production from Mulfab as we speak with side wings for extra capacity.
You seem a little bitter regarding Mulfab as when you left working there with Peter you set up in competition with his ideas .
Competition is a good thing but it’s time you concentrated on your business and stopped bitching about there’s
