2 members (TeddyAds, vincentvg),
204
82
Topics49,848
Posts837,396
Posts: 12 |
Hello together
I would like to change the windscreen on my Morgan next month.... Unfortunately I haven't found anything in the forum.... Does anyone have any recommendations for me?
-Additional hole for the centre screen pillar? -Everything fixed with silicone? (What colour do you recommend?) -With what torque did you fix the screens? -Did you mount something under the centre screen pillar? -Probably there are other points... But the M3W is still in one piece π
Thanks for your help Patrick
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
A guy called Kevin used to cut the screens for Fairbourne and can still supply the screens. I believe he also has some centre pillars available, although only in black. He can be contacted on 07977 070184. I have a set of the original Fairbourne fitting instructions if it helps.
Andy
Posts: 12 |
Hello together
Thank you for your replies ππΌ. I have bought the Morgan fly screen's βΊοΈ
And looking forward to fitting them.
John: Do you have a rubber profile in the middle or was it fixed with silicone? And was it also siliconised at the bottom? Or do you have some photos?
Best thanks
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
Hello Patrick Here's some photos of the heritage screen on my car. You can see the centre pillar is attached to the tonneau cover pin bolt. Feeling underneath the pillar there seems to be a second bolt towards the front of the pillar that is invisible from above, and it does feel like there is some sort of plate beneath the bodywork. I can't take photos of that without pulling the car apart though, and it is too damn hot in my garage for that! Hope this helps John ![[Linked Image]](https://www.tm-img.com/images/2022/06/30/IMG_4711-copy.jpg) ![[Linked Image]](https://www.tm-img.com/images/2022/06/30/IMG_4710-copy.jpg) ![[Linked Image]](https://www.tm-img.com/images/2022/06/30/IMG_4709-copy.jpg)
2020 M3W
