Topics49,846
Posts837,385
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
temp gauge reading slightly high but steady as a rock .... checked with my laser/IR thermometer when I got back and block sitting at 83° and upper rad tank at 70° so, as I suspected, it's the gauge over-reading ... can sort that at my leisure.
Looks fabulous. Had a similar issue with my temp, but fitted a solid state voltage regulator from Spyida and it sits just right now.
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
Brilliant Keith, she's looking great as well as running well. I'll keep a lookout for you around the local area.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
I did yesterday, trip to the MOT station and it failed because no rear brake lights working Mechanic got his elec tester thing out, checked all fuses etc…. and it was the brake switch with a poor contact. Quickly removed and cleaned and all working and passed the MOT. I might order a replacement switch from Mr. Rutter and keep as a spare ? Glad to see you got it sorted Craig. Might be worth having a spare, but it may outlive the car! Sounds like under use if a clean up sorted the problems. A bit more  between Mot's? Phil
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
I did yesterday, trip to the MOT station and it failed because no rear brake lights working Mechanic got his elec tester thing out, checked all fuses etc…. and it was the brake switch with a poor contact. Quickly removed and cleaned and all working and passed the MOT. I might order a replacement switch from Mr. Rutter and keep as a spare ? Glad to see you got it sorted Craig. Might be worth having a spare, but it may outlive the car! Sounds like under use if a clean up sorted the problems. A bit more  between Mot's? Phil Thanks Phil I did cover 1,900 miles between MOT,s not bad for the odd weekend driving
Craig Jezz
Good news on the pass Craig, I'm always a bit apprehensive about the emissions on mine.
I see the garage you use has the same ramp with hydraulic plates to test front suspension wear. What milage is on your car and is there any top/bottom movement due to kingpin wear?
Curious because I get wear noted on the offside every year yet it never seems to get any worse. It's also noted on some of the certificates from before I purchased the car. I suspect a lack of greasing from previous owners but could be wrong
Last edited by Gordon D; 30/06/22 06:15 AM. Reason: Removed post as it appeared twice.
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
Easy to remove entire post when you use the "Edit" function. Just select "Delete post" button
I did yesterday, trip to the MOT station and it failed because no rear brake lights working Mechanic got his elec tester thing out, checked all fuses etc…. and it was the brake switch with a poor contact. Quickly removed and cleaned and all working and passed the MOT. I might order a replacement switch from Mr. Rutter and keep as a spare ? Glad to see you got it sorted Craig. Might be worth having a spare, but it may outlive the car! Sounds like under use if a clean up sorted the problems. A bit more  between Mot's? Phil Thanks Phil I did cover 1,900 miles between MOT,s not bad for the odd weekend driving  I did more than that last week!
