3 members (Bitsobrits, TBM, Bishmog), 242 guests, and 87 robots.
Topics49,847
Posts837,389
Page 1,255 of 1,342 1 2 1253 1254 1255 1256 1257 1341 1342
TBM Online Content
Originally Posted by Image
temp gauge reading slightly high but steady as a rock .... checked with my laser/IR thermometer when I got back and block sitting at 83° and upper rad tank at 70° so, as I suspected, it's the gauge over-reading ... can sort that at my leisure.
Looks fabulous.
Had a similar issue with my temp, but fitted a solid state voltage regulator from Spyida and it sits just right now.
Brilliant Keith, she's looking great as well as running well. I'll keep a lookout for you around the local area.
Gordon Duguid
I did yesterday, trip to the MOT station and it failed because no rear brake lights working swear
Mechanic got his elec tester thing out, checked all fuses etc…. and it was the brake switch with a poor contact. Quickly removed and cleaned and all working and passed the MOT. I might order a replacement switch from Mr. Rutter and keep as a spare ?
Craig Jezz
+1, the car looks lovely
Glad to see you got it sorted Craig. Might be worth having a spare, but it may outlive the car! Sounds like under use if a clean up sorted the problems. A bit more
drive between Mot's?
Phil
06 Saab 93
Phil
Thanks Phil
I did cover 1,900 miles between MOT,s not bad for the odd weekend driving grin2
Craig Jezz
Good news on the pass Craig, I'm always a bit apprehensive about the emissions on mine.
I see the garage you use has the same ramp with hydraulic plates to test front suspension wear. What milage is on your car and is there any top/bottom movement due to kingpin wear?
Curious because I get wear noted on the offside every year yet it never seems to get any worse. It's also noted on some of the certificates from before I purchased the car. I suspect a lack of greasing from previous owners but could be wrong
Gordon Duguid
Last edited by Gordon D; 30/06/22 06:15 AM. Reason: Removed post as it appeared twice.
Gordon Duguid
Originally Posted by Gordon D
Easy to remove entire post when you use the "Edit" function. Just select "Delete post" button smile
Phil
Thanks Phil
I did more than that last week!
06 Saab 93
