8 members (JohnHarris, Mats, Montegue, stumog, Gordon D, Image, John V6, TalkMorgan),
376
82
Topics49,848
Posts837,408
Posts: 46 |
Hi everyone!
After a period of Bentley and Jag ownership I am back with a Morgan. :-)
There really is no substitute! :-)
I have been told that I should change my intake filter for a filter with better flow (to let the engine breathe a bit better), but no one has been able to recommend a specific filter for me to buy.
Any input would be appreciated!
Best regards
Jens
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Jens
I assume that you the standard black filter box with the trumpet intake on the right hand side (looking forwards) You will get a marginal improvement by using a K&N filter element inside the box but the design is quite restrictive , especially if you have any other engine modifications , and is best replaced by a "cone" type filter which bolts directly onto the air mass sensor.
There are 2 types , the K&N type which uses a fabric filter element , this is cleaned with water , and re-oiled every year or so. I use a JR one , but it did require some minor mods to ensure a good fit.
The other is a foam type element , this is again cleaned with water, I am not sure who supplies these, but all the Racing +8s in the Aero Racing Challenge use them, so ask someone like Bret at BHM who prepares Steve Lockett's car.
Posts: 46 |
Thank you so much!
It was a K&N Cone type filter that I had in mind, but I am unable to find which one to buy. There seems to be a million different versions, and the K&N website does not list any a suitable for Morgan, or even the 3.9l Rover engine itself for that matter.
Any thoughts?
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Jens, I cannot help too much but I remember this thread a year ago where Cain Pulton at Wolf Performance is mentioned as a source of help among other advice. http://www.talkmorgan.com/ubbthreads.php/topics/711087/1
Posts: 201 Likes: 8
Posts: 201 Likes: 8 |
I asked the same question a while ago and was recommended the K&N RG-1001BL RG, which I’ve bought, but not figured out how to fit it it without grounding the MAF sensor. I have just tracked down an old black air box to cut up to try and make a mount, though maybe Andy G could share a photo of his installation for inspiration?
Mike H Bourgogne Franche Comté
though maybe Andy G could share a photo of his installation for inspiration? Will do later today.
I hope this will suffice ![[Linked Image]](https://www.tm-img.com/images/2022/07/05/8-engine-6798.jpg)
I though maybe Andy G could share a photo of his installation for inspiration? Do you need a close up view of the actual mounting between the AMS and the filter? I seem to remember that there was a minor amount of machining involved before I could use the JR filter . It was done by a guy who advertised in Miscellany , but this was 20+ years ago.
Posts: 46 |
Thank you! :-) That would be very helpful!
Best regards
Jens
This is the open end of the air mass sensor showing the 2 over centre clips. The K&N filler has a rubber coated rim which fits over this flange and is secured by a jubilee clip . Does this give you the idea ![[Linked Image]](https://tm-img.com/images/2022/07/05/IMG_4884.jpg)
