0 members (),
174
92
Topics49,847
Posts837,389
Posts: 3,847 Likes: 400
Posts: 3,847 Likes: 400 |
Thanks for that Peter very interesting article, it took me back to my metalwork class school days,when we produced metal castings in sand moulds......always very unnerving time handling the heavy very hot pouring ladle, trying to pour accurately, quickly with the least spitting and splash back................
22 Plus Four KIMI 12 Plus 4 Sport OZZY 08 Roadster FELIX 06 4/4 70th LOKI 77 4/4 SEAMUS 85 4/4 MOLLY
Posts: 1,415 |
Brake cylinder bores should be roller burnished to finished size. This cold forms the metal surface and leaves the best surface finish for the seals to run against. My suspicion is that the boring operation on the existing master cylinders is breaking into an area of porosity within the casting, and that area is destroying the seals. . roundy roundy smoothing I'm interested to see what the fix is for the radiators- I've seen talk of swirl pot- that's not going to help the welds splitting on the tanks...
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
I suspect you are absolutely right, Simon.
As to the radiator header tank welds splitting, is it possible that some form of cavitation is vibrating the coolant, resulting in fatigue fractures of the welds, and they think a swirl pot would remove the cavitation and protect the rad? I'm speculating: a well made aluminum radiator should be robust. So it the OEM radiator just "cheap" and not very robust?
Posts: 33 |
I received a email on June 30 saying that a small number of vehicles would be rectified at the factory and mine was one. I should expect a call in the next 10 days to arrange collection and that the car would be with Morgan for 7-14 days to carry out the work. This evening I have received an email from MMC as follows:
We are sincerely sorry for the disruption that you have faced as a result of the stop drive recall affecting Morgan Plus Four and Plus Six vehicles. We are eager to communicate updates to affected customers as regularly as possible. We have been validating a technical fix as thoroughly and swiftly as possible, and this process is nearing completion. Whilst we must await the final results of this process, along with the sourcing of components, we are pleased to say that early indications are leading to a high level of confidence in the fix. Once this process is complete, we plan to begin shipping the required parts to the Morgan dealer network, allowing them to begin rectification works to affected cars.
So, basically they haven’t yet finally decided on a fix, let alone sourced or shipped the parts. This leads me to conclude that it is highly unlikely the car will be on the road again this summer. Having bought the car in 2020 and having two years of Covid (no-ones fault) and now this, I am sure most would understand why I am beginning to regret this very large purchase.
Posts: 206 Likes: 15
Posts: 206 Likes: 15 |
It could not have come at a worse time at the start of Summer there must be some form of compensation to be paid for the time the cars have been forced off the road?
Previous Mog Plus 4 Fiat Twin Cam. Plus Six
Posts: 26 |
I purchased a Plus Four (CX) in February 2021 and deprived great pleasure from owning and driving it since then although my driving has been limited by personal circumstances. Consequently to be told in course of a telephone conversation in early June that I should cease to drive it because of a safety issue and receiving the letter of the 8th June 2022 caused intense concern not least because my pride and joy has since remained in my garage, in a Carcoon and connected to a trickle charger for upwards of four weeks because it cannot be driven on the public highway. Planned outings have been frustrated On present appearances this situation is likely to continue into the Autumn.
The letter reads in part “We would like to advise you that ongoing quality assessment of our product we have identified a possible safety related issue in respect of all Morgan Plus Four and Plus Six vehicles. Preliminary investigations indicate that in certain circumstances, premature degradation of the rubber seal(s) in the brake master cylinder may result in compromised brake performance and in extreme cases cause brake failure. Because this is a possible safety issue ……….”
The recall order was apparently dated the 1st June and was made apparently in respect of Morgan CX cars not in respect of a list of cars including those of other companies with a like or similar brake master cylinders and/or seals. Certainly I cannot trace a recall orders in like terms relating to other makes of car but I have not made formal inquiries of the GOV.Uk site because I do not know the identity of the models fitted with a like brake cylinder.
I am not an engineer nor a car mechanic nor a car expert but I have read the threads and comments in Talk Morgan. It seems unlikely to me that the brake cylinder was designed specifically for the CX models. I assume it was designed and produced with specified materials for use in other cars (MMC do not appear to have the resources to finance the design and development of a specific brake cylinder for the CX models). Also It also seems unlikely to me that the brake fluid is specific to Morgan CX cars. As such the brake cylinder as a complete component was accepted as suitable by MMC with or without modification a fitting the technical requirements based not only on a proper evaluation by its own engineers but also in reliance upon the third party warranting that it would meet the technical requirements and assemble each one to the required specification and quality.
In such or like circumstances I am at loss to understand why MMC not been given details about how the present situation has arisen that is to say been frank and open about what is going on given the actual or likely reputational damage to the marque and loss of goodwill with its customers including the selling dealers who have stock which they cannot sell. This kind of damage is likely to destroy the impact of the many favourable reviews in the press and elsewhere and expose MMC to serious criticism. The retail outlets/dealers have been apparently left in an embarrassing position where they cannot deal with legitimate questions from customers and sell new or used CX Morgans,
It the circumstances I say and trust that others will agree that the MMC was and is under an obligation to fully explain in neutral terms how the present state of affairs has arisen. The letter of the 8th June and the subsequent email/letter of the 24th June are wholly inadequate as appears from the comments below.
The list of matters of concern below is not intended to be complete or exclusive
1. As to “ongoing quality assessment” - any quality assessment should have been completed before the CX went on the market. The inference is that such an assessment by MMC or a third party failed to identify the fault which must have appeared in the course of servicing or complaints by drivers as to braking while driving or in the course of an inquiry as to the cause of an accident/collision. 2. On the basis that the brake cylinder including seals and brake fluid must be common to other recently manufactured cars, it would be significant that there has not or has been a vehicle recall in respect of cars with identical brake cylinders unless there is some other fault in construction or design peculiar to CX cars (not necessarily in the brake cylinder) for example use of the alloy which turned out to be porous exclusively in brake cylinders supplied to MMC in accordance with or contrary to the agreed specifications. 3. Whether or not MMC has the financial resources to remedy the situation with or without recourse to the third party supplier of the brake cylinder (which hopefully is a substantial concern good for the money unless MMC is solely responsible for the present situation). 4. Unless the cause of the degradation is identified with certainty used values will be seriously affected. 5. No indication is given as to the time involved so that no owners may make for themselves a realistic decision whether or not to apply for a SORN or to vary insurance cover despite the administrative cost. Of particular concern is this regard is the question of how long it will take to produce replacement components given the present economic upheavals
Others may not have the same concerns or different concerns but I say with respect to all that is about time MMC started to be open and frank . My patience and presumably the patience of others has worn thin.
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Hawki of this parish who lost his long in & can't get a new one yet from Simon hasnot seen any progress. The dealer clearly has no idea of when this agony ends.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Couple of personal observations if I had a CX
Bang it on SORN now, you can re-tax it in 5 minutes when needed
You won't get any reduction in insurance cost (used to be called laid up) as they are covering stuff like theft, fire, your paint tin shelf falling off the wall on it, etc. I enquired during the Covid lockdown
Posts: 12 |
A little update from Morgan.
"Dear Morgan customer,
The next step will be for your Morgan dealer to contact you to arrange for your vehicle to be rectified.
Thank you again for your patience whilst we deal with these challenging circumstances. Please be assured that we continue to work tirelessly to get your Morgan sports car back on the road as quickly as possible.
Yours faithfully,
Morgan Motor Company"
Posts: 399 Likes: 15
Posts: 399 Likes: 15 |
I do not envy Morgan management (and the company owners) on this. Clear safety related issue means the level of risk required the stop/don't drive decision. Morgan do not have the scale of resource nor the dealer network to deal with this quickly - they need to re-engineer/validate/source the solution (and the one for the radiators) and mobilise the small number of dealers to deal with 4+ years of production/sales.
From my own experience of managing such issues in a big corporate, this will take months to fix and require huge effort on end customer relationships...another huge challenge for small Morgan and limited number dealers...
This is the "hidden" risk of buying a car from a small specialist esp as car systems get ever more complex requiring much engineering effort to be applied to the digital bits which may mean the basics (brakes/cooling) are treated as "simple to get right".
They sort of got away with it with the M3W although for us early owners it has been a bit of a journey with a couple of periods of "don't drive" (chassis/brake pedal). Very sorry for Plus Six/Four owners who will likely miss all this summer...
The objective of the Plus Four/Six and the new Super 3 is to arttact new customers who may not appreciate what they are buying ....
