0 members (),
330
52
Posts837,276
Posts: 791 Likes: 143
Posts: 791 Likes: 143 |
My twin FIAMM horns are mounted high in the cowl on a home made aluminium bracket gizmo cut from 6mm sheet with a clamp to the cross bar.. Keeps water out of the horn workings. No issues after 2 years in use. ![[Linked Image]](https://www.tm-img.com/images/2022/07/18/IMG_3021.jpg)
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Posts: 1,702 Likes: 35
Posts: 1,702 Likes: 35 |
Super neat job Chris
Roger 2011 Plus 4
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Wow...toot, toot
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
Craig Jezz
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Very nice solution.
If I only had the mashines and the know how to make such parts..
This is the OE snail style horn taken apart, despite many weeks of dry weather the water trapped inside had not dried out This was removed from a Mog yesterday that failed it's MOT for no horn, after removing all the corrosion from the diaphragm and a clean up - it now works perfectly ![[Linked Image]](https://www.tm-img.com/images/2022/07/19/Horn.jpg)
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
My twin FIAMM horns are mounted high in the cowl on a home made aluminium bracket gizmo cut from 6mm sheet with a clamp to the cross bar.. Keeps water out of the horn workings. No issues after 2 years in use. ![[Linked Image]](https://www.tm-img.com/images/2022/07/18/IMG_3021.jpg) Very nice indeed. Should be well above the bow wave from 20cm of standing water This is the OE snail style horn taken apart, despite many weeks of dry weather the water trapped inside had not dried out This was removed from a Mog yesterday that failed it's MOT for no horn, after removing all the corrosion from the diaphragm and a clean up - it now works perfectly ![[Linked Image]](https://www.tm-img.com/images/2022/07/19/Horn.jpg) I must drag out the pair of FIAMM horns. After 4 years they should be dry inside  Perhaps I can revive them. Worth a try anyway.
Posts: 158 Likes: 4
Posts: 158 Likes: 4 |
Bought exactly the same, now everything's fine and the new sound makes me want to honk all the time
