6 members (Craig Jezz, Julian BB, linklaw, +8Rich, rossocorsa, Grumpy2), 246 guests, and 43 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,335
Christoph
There must be something inside the cocoa tin. It is too big for a few transistors.
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Pertronix - the name just reappeared on another forum - wonder if it's one of those?
Cheers,
I had a Pertronix system on a V8 Daimler, everything was inside the distributer cap.
Not one of those then! smile
Graham
2n2055 springs to mind
Yup, that a type, but not the encapsulation... smile
Comment from a Mog pal in USA (who is also into Rileys and other classic cars, plus boat)
"I can see an old style Lucas windscreen wiper motor, some old plugs and the can. This appears to have three old transistor rectifiers in the top. Could be wired to convert AC current to DC. I have never seen that exact arrangement before."
Need to know what those wires lead to? The distributor? Alternator? etc.
Cheers,
Pat L Offline OP
Graham, the wires from the "can".. two go directly to the coil and the other one goes to the dist.
Pat
That confirms an ignition booster then.
Thanks Pat.
Cheers,
Passed your reply on Pat, with a suggestion that maybe it was home made, and another of the group came back with this:
"Yep, that's what it appears to be, a home made ignition booster, the 3 transistors are the guts of a DC voltage amplifying and refining circuit. Wish Fred Winterburn from Canada (ex eMog, on theMog Google Group sometimes) was here, he would know instantly what it is. Apparently his Dad originated a design for CD ignition and variants starting in the 50s, so he is real up on early high performance/solid state ignition systems..."
Cheers,
