1 members (Black Adder),
229
35
Topics49,900
Posts838,038
Posts: 8,697 Likes: 416
Posts: 8,697 Likes: 416 |
Thanks Guys,
This advice was from the Oz Morgan agent here in Melbourne. He (apparently) sourced the info from Morgan UK! For technology decades old it completely threw me. Moreover, I thought the wire wheel would be flush with the drum for added security and remove reliance on what are quite short small screw bolts! I have emailed Morgan but will now contact Brands Hatch Morgan as recommended. Forking out GBP 2000 for parts alone did not go down well with my "manager"!
That's not possible because wire wheel hubs fit onto an aligning taper leaving them necessarily proud of the brake drum face as with most wire wheels. The four setscrews holding on brake drum are more than adequate if correct washers are used and they are tightened sufficiently.
Posts: 6 |
Thanks Richard. Now I understand.
Posts: 8,698 Likes: 498
Posts: 8,698 Likes: 498 |
The Wire wheels definitely stand off the rear drums & even have a concave inner that does not hold the setscrews in place, if you service the rears best to replace the little star washers with new & add a drop of blue loctite This is what your brakes will look like inside the drum & everything is available ![[Linked Image]](https://www.tm-img.com/images/2020/04/21/AP-brakes-3.jpg)
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
The Wire wheels definitely stand off the rear drums & even have a concave inner that does not hold the setscrews in place, if you service the rears best to replace the little star washers with new & add a drop of blue loctite This is what your brakes will look like inside the drum & everything is available ![[Linked Image]](https://www.tm-img.com/images/2020/04/21/AP-brakes-3.jpg) May be worth mentioning to the uninitiated that the linings are of different thickness. The leading shoe does more work when braking as the rotation of the drum pulls it even tighter to the braking surface and increases the braking effect.
Posts: 5,463 Likes: 476
Posts: 5,463 Likes: 476 |
I have no idea of how many sets of rear brake shoes I have fitted in the fifty or more years I have done so but never noted a difference in thickness of lining material until Richard V6 put me right..!!!
As for the OP`s drum coming loose... Perhaps like me whoever fitted the brake drum last had not worked on a wire wheeled car before, and just nipped up the set screws securing the drum thinking the wheel played a part in securing the drum to the hub as it does in a "normal" set-up, and where over-tightened screws ever tend to seize and can create issues when trying to remove them at some later date..?
Posts: 6 |
As recommended, I made contact with the Brands Hatch Morgan team - great blokes. Thanks Paul.
A replacement wheel drum is apparently difficult to source at the moment. Just a shame that the drum that worked loose was beyond repair with holes for the four retaining bolts/screws becoming elongated.
