Topics49,868
Posts837,640
Posts: 141 Likes: 2
Posts: 141 Likes: 2 |
I have a 2012 plus 4 Super Sport 60th Anniversary 200bhp model which has only done just over 5k miles and I'm finding the clutch takes right at the top. In last week it has got very sensitive with a very quick and sudden bite almost at the full extent of travel so easy to stall. Is it about to give out on me or can these be adjusted? I've only done 450 miles with it in the last 2 months and the previous owner said it's never been tracked so really suprised if it's on it's way out unless previuos owner rode the clutch as nowhere really to rest your clutch foot? Any ideas welcomed  . Cheers
AnDrew G 2003 Aero S1 - past 2009 Aeromax - past 2012 +4 Supersport - past 2008 Aero S4 -past
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
I would start with the easy stuff first. Change the fluid.
Then re-rubber or replace master cylinder and if the slave is external, that also.
Standing idle can affect the seals.
Posts: 28,902 Likes: 352
Posts: 28,902 Likes: 352 |
Agree with Dave - start with the easy bits.
Posts: 8,682 Likes: 493
Posts: 8,682 Likes: 493 |
Very difficult to get seals for the 'modern' master cyl, so it's a replace or re-sleeve, but new Caparo ones are available (note Morgan specific part)
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
Agree with Dave - start with the easy bits. Agreed. with luck it is crap fluid. When was it last changed?
Posts: 141 Likes: 2
Agree with Dave - start with the easy bits. Agreed. with luck it is crap fluid. When was it last changed? As the car has only 10 years old and done 5400 miles doubt clutch fluid ever changed. Will try get this looked at with a specialist as 2 Morgans and now not driving either which is frustrating (Aero has different issues regarding VIN numbers). Cheers
Remove the cap and have a look as a first go round. If it is not clear & dark it is cream crackered. After 2 year the fluid will really deteriorate. Any good gargae can change it.
Posts: 141 Likes: 2
Remove the cap and have a look as a first go round. If it is not clear & dark it is cream crackered. After 2 year the fluid will really deteriorate. Any good gargae can change it. Thanks John, had a look and as can be seen in the photo looks ok (I'm mechanically inept) but found wedged an 18 inch plastic tube not attached to anything though looks like should be attached to the pipe you can see in the middle of the photo (if it's loaded)? The plastic tube has split and have no idea if this is realted to the clutch or not? <img src="https://www.tm-img.com/images/2022/08/03/20220803_182355.jpg" alt="20220803_182355.jpg" border="0" />
Posts: 141 Likes: 2
Posts: 141 Likes: 2
