1 members (DJC),
346
42
Topics49,844
Posts837,360
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
I once sat in a Mog that had ex landrover headrests. They were taller and slightly angled. Same fitting. They felt really good. Nick
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Mine have never gone all the way in - not on my 2013 or 2020 Roadster. I think they are meant to protrude a couple of inches. My problem is also removing them - almost impossible. I sprayed the stems with some dry lube that I use on hedge trimmer blades
Posts: 22,357 Likes: 353
Posts: 22,357 Likes: 353 |
Yes they were BLs finest, fitted across the range, Allegro, Marina, Triumph, MG, Jaguar.
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
IMHO, headrests are not provided for comfort nor to snuggle into. They are there to prevent a broken neck in the event of a collision, particularly from behind. Adding a neck roll, arguably provides a nice pivot point to ensure the neck snaps more cleanly!
Posts: 1,394 Likes: 257
formerly known as Hugh Jorgan Has a lot to Say!
Posts: 1,394 Likes: 257 |
I've always thought the head rests spoil the lines of a Morgan. I have hacksawed a couple of inches off the end of the metal tube in the past to get them to go down flush with the seat back. I take them off and store them away and use 2 little plastic plugs that are from an MG to fill the hole in. I think they're angled way too far back to be of any benefit to reduce whiplash in the event of being rear ended.
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
Mine have never gone all the way in - not on my 2013 or 2020 Roadster. I think they are meant to protrude a couple of inches. My problem is also removing them - almost impossible. I sprayed the stems with some dry lube that I use on hedge trimmer blades Good tip - thanks.
David 2020 Roadster 3.7 Dove Grey.
Posts: 792 Likes: 143
Posts: 792 Likes: 143 |
If the headrest tube is cut to lower the headrest down to the seat it may interfere with seat belt retraction. Solution is to pivot the plastic seatbelt guide away from the headrest. Don’t ask how I know this !
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
There is guidance on proper fitment of head restraints from ROSPA where you will see that the head restraint should be touching the top of the head to be effective, so do check before chopping bits off to make it look pretty. Life may depend on it. https://www.rospa.com/rospaweb/docs/advice-services/road-safety/vehicles/adjust-head-restraints.pdf
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
IMHO, headrests are not provided for comfort nor to snuggle into. They are there to prevent a broken neck in the event of a collision, particularly from behind. Adding a neck roll, arguably provides a nice pivot point to ensure the neck snaps more cleanly! Absolutely.
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
Before ![[Linked Image]](https://i.imgur.com/glqBlCf.jpg) After two minutes with the Dremel ![[Linked Image]](https://i.imgur.com/kTt2HLZ.jpg) Happy bunny.
