2 members (DaveK, MOGDave),
256
43
Topics49,844
Posts837,360
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
I cannot get my headrests to slide all the way into the seat backs. There is a gap of an inch or so. It is not stiffness - we have used WD40 liberally. Is there something in the sleeve that we need to remove?
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
If it's your Roadster, you need to give it some more wellie, then the problem is removing them - where you heave & tug and it flies into the air and pings off your lovely paintwork
Posts: 5,437 Likes: 131
Black Rat Charter Member
Posts: 5,437 Likes: 131 |
I don't think they go right in my 2013 + 4 are the same.
Posts: 1,982 Likes: 103
Posts: 1,982 Likes: 103 |
They go all the way in on my 2009 Roadster. ![[Linked Image]](https://www.tm-img.com/images/2022/08/02/Roadster-seats.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
They go all the way in on my 2009 Roadster. ![[Linked Image]](https://www.tm-img.com/images/2022/08/02/Roadster-seats.jpg) Thank you. What am I doing wrong? They slide in and out easily, but stop short of yours. I have just taken delivery of a pair of Allon White neck rolls, and the headrests need to be tight to the top of the seat to stop them from moving around.
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
Mine have never gone all the way in - not on my 2013 or 2020 Roadster. I think they are meant to protrude a couple of inches. My problem is also removing them - almost impossible.
David 2020 Roadster 3.7 Dove Grey.
Posts: 208 Likes: 7
Posts: 208 Likes: 7 |
You need to shorten the rod a little less than the current height. Then don't forget to flatten the stem and polish the trimmings well.
The previous advice to give it more welly sounds about right -- to get mine to insert the last inch requires quite a good whack with the flat of my hand (in best Will Smith style....). Phil at Allon White can probably give you a more technical explanation. Not sure where those flattened tubes came from originally, but I had the exact same headrest setup in all of my TVR M-Series and S-Series, so I'm guessing they have been around for at least 4 decades. (The TVR's had a different method of finishing the leather seatbacks, which meant it was easy to get your hand "up there" to figure where all the bits fitted). ![[Linked Image]](https://www.tm-img.com/images/2022/08/02/TVR-S-Series-headrests.jpg)
That may well be the answer. I will see if I can borrow a Dremel tomorrow.
Posts: 3,560 Likes: 12
Posts: 3,560 Likes: 12 |
I think the frames were originally fitted to MGBs or similar in the '60's. I wish they worked and actually ended up a little closer to the back of the head, so you didn't need neck rolls.
