4 members (Deejay, MartinB60, bmgermany, Montegue), 261 guests, and 24 robots.
+8Rich 84
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,361
#750407 02/08/22 06:08 PM
M3W55 Offline OP
I cannot get my headrests to slide all the way into the seat backs. There is a gap of an inch or so. It is not stiffness - we have used WD40 liberally. Is there something in the sleeve that we need to remove?
M3W55 #750416 02/08/22 07:02 PM
If it's your Roadster, you need to give it some more wellie, then the problem is removing them - where you heave & tug and it flies into the air and pings off your lovely paintwork frown
M3W55 #750424 02/08/22 07:48 PM
Black Rat
Black Rat
I don't think they go right in my 2013 + 4 are the same.
Keith
2013 narrow bodied + 4 Ruby.
Burgundymog #750426 02/08/22 07:54 PM
They go all the way in on my 2009 Roadster.
M3W55 Offline OP
Thank you. What am I doing wrong? They slide in and out easily, but stop short of yours.
I have just taken delivery of a pair of Allon White neck rolls, and the headrests need to be tight to the top of the seat to stop them from moving around.
M3W55 #750429 02/08/22 08:05 PM
Mine have never gone all the way in - not on my 2013 or 2020 Roadster. I think they are meant to protrude a couple of inches. My problem is also removing them - almost impossible.
David
2020 Roadster 3.7 Dove Grey.
M3W55 #750430 02/08/22 08:08 PM
You need to shorten the rod a little less than the current height. Then don't forget to flatten the stem and polish the trimmings well.
M3W55 #750431 02/08/22 08:17 PM
The previous advice to give it more welly sounds about right -- to get mine to insert the last inch requires quite a good whack with the flat of my hand (in best Will Smith style....). Phil at Allon White can probably give you a more technical explanation. Not sure where those flattened tubes came from originally, but I had the exact same headrest setup in all of my TVR M-Series and S-Series, so I'm guessing they have been around for at least 4 decades. (The TVR's had a different method of finishing the leather seatbacks, which meant it was easy to get your hand "up there" to figure where all the bits fitted).
gaston #750433 02/08/22 08:35 PM
M3W55 Offline OP
That may well be the answer. I will see if I can borrow a Dremel tomorrow.
M3W55 #750543 03/08/22 02:27 PM
I think the frames were originally fitted to MGBs or similar in the '60's. I wish they worked and actually ended up a little closer to the back of the head, so you didn't need neck rolls.
