6 members (DaveW, Zach, TBM, gaston, Mogdavid, vincentvg), 336 guests, and 42 robots.
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,371
M3W55 #750553 03/08/22 02:57 PM
I once sat in a Mog that had ex landrover headrests. They were taller and slightly angled. Same fitting. They felt really good.
Nick
Quicksilver #750570 03/08/22 05:15 PM
Originally Posted by Quicksilver
Mine have never gone all the way in - not on my 2013 or 2020 Roadster. I think they are meant to protrude a couple of inches. My problem is also removing them - almost impossible.
I sprayed the stems with some dry lube that I use on hedge trimmer blades
M3W55 #750584 03/08/22 05:56 PM
Yes they were BLs finest, fitted across the range, Allegro, Marina, Triumph, MG, Jaguar.
M3W55 #750595 03/08/22 06:20 PM
IMHO, headrests are not provided for comfort nor to snuggle into. They are there to prevent a broken neck in the event of a collision, particularly from behind. Adding a neck roll, arguably provides a nice pivot point to ensure the neck snaps more cleanly!
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
M3W55 #750603 03/08/22 06:37 PM
formerly known as Hugh Jorgan
I've always thought the head rests spoil the lines of a Morgan.
I have hacksawed a couple of inches off the end of the metal tube in the past to get them to go down flush with the seat back.
I take them off and store them away and use 2 little plastic plugs that are from an MG to fill the hole in.
I think they're angled way too far back to be of any benefit to reduce whiplash in the event of being rear ended.
CooperMan #750616 03/08/22 08:22 PM
Good tip - thanks.
David
2020 Roadster 3.7 Dove Grey.
M3W55 #750621 03/08/22 08:46 PM
If the headrest tube is cut to lower the headrest down to the seat it may interfere with seat belt retraction. Solution is to pivot the plastic seatbelt guide away from the headrest. Don’t ask how I know this !
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
M3W55 #750663 04/08/22 07:39 AM
There is guidance on proper fitment of head restraints from ROSPA where you will see that the head restraint should be touching the top of the head to be effective, so do check before chopping bits off to make it look pretty. Life may depend on it.
https://www.rospa.com/rospaweb/docs/advice-services/road-safety/vehicles/adjust-head-restraints.pdf
Doug
1958 Triton 650
Deejay #750666 04/08/22 07:45 AM
Black Rat
Black Rat
Absolutely.
Keith
2013 narrow bodied + 4 Ruby.
M3W55 #750706 04/08/22 12:41 PM
M3W55 Offline OP
Before
After two minutes with the Dremel
Happy bunny.
