8 members (Oliemog, Stevo666, Craig Jezz, Dougie, Morganmike, Graham, G4FUJ, flyfisher, Pyewacket),
240
46
Topics49,911
Posts838,145
Posts: 172 |
Please can anyone advise the correct oil for the Gemmer steering box on our car? I think the recommendation in the handbook that came with the car refers to the earlier box.
Thanks
Jack
Jack 1985 4/4 T/C 4 seater Royal Ivory 1934 F Type 2018 Pembleton SuperSport (self built).
Posts: 3,829 Likes: 69
Posts: 3,829 Likes: 69 |
Acording to my 1987 plus 4 handbook (gemma box) it's Castrol hypoy ep90, or duckhams 90s. Or texaco multigear ep 85w 90 Hope that helps but it is the handbook that came with the car so I can't be absolutely sure it applies to the gemma box. Nick
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
I'm by no means an authority on this subject but in the past I used Millers Vintage Worm Steering Box Oil in my 4/4s Gemmer steering box with no adverse effect
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 287 Likes: 8
Posts: 287 Likes: 8
![[Linked Image]](https://www.tm-img.com/images/2020/02/06/GEDC0026.jpg) Ah,so it is Gemmer !
Posts: 172 |
Acording to my 1987 plus 4 handbook (gemma box) it's Castrol hypoy ep90, or duckhams 90s. Or texaco multigear ep 85w 90 Hope that helps but it is the handbook that came with the car so I can't be absolutely sure it applies to the gemma box. Nick Nick, Thanks, that is the same info as in my 1985 handbook, hopefully Morgan would have changed in 2 years if an update was needed!
Acording to my 1987 plus 4 handbook (gemma box) it's Castrol hypoy ep90, or duckhams 90s. Or texaco multigear ep 85w 90 Hope that helps but it is the handbook that came with the car so I can't be absolutely sure it applies to the gemma box. Nick Nick, Thanks, that is the same info as in my 1985 handbook, hopefully Morgan would have changed in 2 years if an update was needed! I wouldn't be sure..it all depends how many they'd had printed...bound to use them all could easily be out of date!
Posts: 161 |
I use Millers classic worm steering oil. Fairly easy to find on line. I use a tube and big plastic syringe and suck out the old oil from the top. Has worked well.
- Nelson
1966 Plus 4 RHD
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
I use a decent brand 75/90 with a bit of Molyslip added
Works a treat
Arwyn
