0 members (),
335
37
Topics49,915
Posts838,214
Posts: 8,708 Likes: 501
Posts: 8,708 Likes: 501 |
Power Torque still offer this Cyclone variant. ![[Linked Image]](https://i.imgur.com/DKyHmov.jpg) Looks quite compact. Variants 310-660 hp  Problem is it looks turboed, so going out in the Mog for a spin...would be literal
Posts: 8,704 Likes: 416
Posts: 8,704 Likes: 416 |
Power Torque still offer this Cyclone variant. ![[Linked Image]](https://i.imgur.com/DKyHmov.jpg) Looks quite compact. Variants 310-660 hp  Problem is it looks turboed, so going out in the Mog for a spin...would be literal Err yes - just like a Plus Six on steroids
Posts: 27,852 Likes: 767
Posts: 27,852 Likes: 767 |
Yes an insert. Moulds are machined in sections
Apologies for re-opening this old thread but wanted to correct some reported repair errors. The lower inlet manifold also carries the top coolant rail but being plastic doesn't transmit the heat to inlet tracts. It takes six individual soft rubber gaskets with grooves to allow accurate placement. The upper inlet manifold sits above secured by screws into threaded inserts on lower. This takes two rubber gaskets, one for each bank, again located by grooves. It would be possible to fit any of these gaskets incorrectly though which is likely what happened in the OP's case during Ford's engine build and clearly nothing MMC could have caused or prevented since engine supplied to them complete. The correct cure would be to fit fresh gasket(s) correctly inserted not glued! Lower inlet manifold (shown inverted) and full gasket set (Elring 856.670) below. ![[Linked Image]](https://i.imgur.com/q95P59o.jpg) ![[Linked Image]](https://i.imgur.com/R1G6yN1.jpg)
