7 members (hugo, RichB, IcePack, RichardV6, Alan Patterson, howard, Rex_tulips),
285
Topics48,362
Posts813,331
Members9,215
Posts: 756 Likes: 9
Posts: 756 Likes: 9 |
What matters most to me is the impedance I've been looking for the right length and impedance for several weeks now and I haven't found it yet, generally it doesn't give a diameter for $10 I risk myself cheaply and for the length is not a big issue for me the harley sensor is not available from aliexpres currently.
I just bought a timing belt from Morgan this afternoon to get spare parts ahead of time, the price has gone up.
Posts: 2,356 Likes: 2
Posts: 2,356 Likes: 2 |
Posts: 695 Likes: 6
Toys for Boys Talk Morgan Regular
Posts: 695 Likes: 6 |
Stunning work as always! Will be in touch.
Omne trium perfectum
Posts: 34 Likes: 1
Posts: 34 Likes: 1 |
For those looking to purchase a replacement Crank Position Sensor Kit 106-0734.
S&S just produced some inventory, You'll need to call direct to place your order, it's not listed on the S&S web site.
I just received my spare! the price was reasonable too!
M3W Plus 4
Posts: 1,673 Likes: 25
Posts: 1,673 Likes: 25 |
For those looking to purchase a replacement Crank Position Sensor Kit 106-0734. S&S just produced some inventory, You'll need to call direct to place your order, it's not listed on the S&S web site. I just received my spare! the price was reasonable too. What do you call reasonable? Just asking for a friend...
Andy
Posts: 34 Likes: 1
Their list price... $129 plus tax...
M3W Plus 4
Posts: 756 Likes: 9
Posts: 1,562 |
Hi GLLOQ,
Can you expand on "modify the diameter please" , do you mean the diameter of the sensor body ?
Thanks
Posts: 756 Likes: 9
I destroyed the fixing with cutting pliers then with the lathe I reduced to half then I turned it over to machine the other side to the correct diameter, the Kia Hyundai sensor at about 1 mm in diameter more and has 1 cm too long, then I fixed an original sensor on the lathe machine 2 mm from the chuck then started at 1000 rpm to see the voltage produced, after I mounted the Kia and realized that I reduced by 0.3 mm to have the same voltage, despite everything 0.2 volts should not matter. ![[Linked Image]](https://zupimages.net/up/22/36/mjtl.jpg) I'll give it a try tomorrow maybe.
Posts: 756 Likes: 9
I mounted the Kia sensor to modify this evening it works for the moment I will test several days and order another sensor to try to make a hollow for the O-ring in the position like the original sensor. ![[Linked Image]](https://zupimages.net/up/22/36/lh1h.jpg)
