7 members (+8Rich, Grumpy2, Image, Tresco, RichardV6, TBM, Rex_tulips), 282 guests, and 38 robots.
+8Rich 64
Adam12 62
John V6 58
9,215 Registered Users
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Tom Lehrer RIP
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,362
Posts813,327
Members9,215
Page 6 of 9 1 2 3 4 5 6 7 8 9
What matters most to me is the impedance I've been looking for the right length and impedance for several weeks now and I haven't found it yet, generally it doesn't give a diameter for $10 I risk myself cheaply and for the length is not a big issue for me the harley sensor is not available from aliexpres currently.
I just bought a timing belt from Morgan this afternoon to get spare parts ahead of time, the price has gone up.
All increase
Toys for Boys
Toys for Boys
Stunning work as always! Will be in touch.
Omne trium perfectum
For those looking to purchase a replacement Crank Position Sensor Kit 106-0734.
S&S just produced some inventory, You'll need to call direct to place your order, it's not listed on the S&S web site.
I just received my spare! the price was reasonable too!
M3W
Plus 4
Bunny Offline OP
Originally Posted by PocketRocket
For those looking to purchase a replacement Crank Position Sensor Kit 106-0734. S&S just produced some inventory, You'll need to call direct to place your order, it's not listed on the S&S web site. I just received my spare! the price was reasonable too.
What do you call reasonable? Just asking for a friend... innocent
Andy
Their list price... $129 plus tax...
M3W
Plus 4
I received the Kia / Hyundai sensor and modify the diameter which is larger and make a fixing, I will stick it to the same depth it may be that the O-ring on the crankcase cone is sufficient.
Hi GLLOQ,
Can you expand on "modify the diameter please" , do you mean the diameter of the sensor body ?
Thanks
I destroyed the fixing with cutting pliers then with the lathe I reduced to half then I turned it over to machine the other side to the correct diameter, the Kia Hyundai sensor at about 1 mm in diameter more and has 1 cm too long, then I fixed an original sensor on the lathe machine 2 mm from the chuck then started at 1000 rpm to see the voltage produced, after I mounted the Kia and realized that I reduced by 0.3 mm to have the same voltage, despite everything 0.2 volts should not matter.
I'll give it a try tomorrow maybe.
I mounted the Kia sensor to modify this evening it works for the moment I will test several days and order another sensor to try to make a hollow for the O-ring in the position like the original sensor.
