5 members (DaveW, RichardV6, gazum, Image, Fuel.inj), 208 guests, and 50 robots.
+8Rich 84
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,366
Page 1,296 of 1,342 1 2 1294 1295 1296 1297 1298 1341 1342
The ones on Peter's picture look like the ones I had on my early S1 with the perforated lining, they were listed on the original invoice as optional extra 'acoustic sports tailpipes' IIRC
That got me thinking. Mine do have perforations inside (hard to photograph), the tailpipes are 42cm long and 7.5cm outside diameter. They stay very clean (in the year since I've had the car I have driven around 2,000 miles, I just wipe over the outside after a day's run). They are very quiet, which is sort of counter-intuitive for a Morgan....[Linked Image]
My outer diameter is the same and the internal not much small as it must only be 1 - 1.5mm thick. It might make exhaust gasses flow quicker, but feel it looks cheap compared to the look of yours. It never gets hot either which surprised me.
2004 Series 1 Roadster
Originally Posted by Leroy
Found an invoice in my file for a morgan sports exhaust system dated 2006, cost just under £600. Supply only from Richard Thorne. I take it that would be everything after the cat, as opposed to the including the cat and manifold as well.
Yes, from cat back
Yes, from cat back
Thanks. Seems a lot for two lengths of bent pipes 😂
It was a dual-purpose day for me. I started by replacing the dashboard mounting screws. One was broken, causing the panel to sag to the point of interfering with closing the passenger door. I used stainless threaded inserts in the framework behind the dash, and switched from brass wood screws to stainless #8-32 oval head machine screws with finishing washers. When I put everything back together, I corrected the alignment of the steering wheel. The last person to attach the wheel must've missed their coffee that morning, because it was canted about 30 degrees anti-clockwise.
Once the heat of the day passed, I took the car on a 60-mile trip through a fairly empty section of my local area. There was next to no traffic, and the breeze was pleasant. Definitely a grin-inducing trip!
Steering wheels off centre are just as likely following tracking adjustment, where most of the adjustment has been incorrectly taken up on one track rod end only.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
30 degrees is a lot though. Replacing the rack gaiters can also cause this. Mine was annoying out by 3 or so degrees after replacing the gaiters. With the Brooklands wheeel it stands out due to the vertical spokes
I replaced a rack gaiter but lowered the car onto wheel ramps to fix them in a steady orientation. This meant no dismantling of anything that would be moved out of position. As a precaution I got the tracking checked and it was unchanged.
My steering wheel is slightly out. I had to getthe horn working for an MOT. It is a Motolita 3 spoke with a quick removal boss. I did a “fix” to get the horn ok but not got round to a final fix. I replaced the boss slightly off centre on the splines so will re-centre it when sorting the horn wiring.
The Grail achieved
But not without incident. A sudden squall overwhelmed the wipers and as I slowed to try and get some visibility I was rear-ended by an articulated lorry that did not see me. That will be a few weeks off the road when we return.
Sorry to hear that. That is the second rear ending I have heard of this week.
