1 members (Montegue),
367
47
Posts837,277
Posts: 11,520 Likes: 312
Posts: 11,520 Likes: 312 |
Yes the PPF can be removed without having to repaint as long as it is not done by a chimp. Heat and patience is needed. Once off the surface needs to be cleaned thoroughly before re-application. If it is 3M you can find a specialist here https://www.3m.co.uk/3M/en_GB/compa...dGroup=AuthorisedVentureshieldInstallersThere are ways of polishing out rubber boot scuff on PPF without having to replace it. Some of these can be found in this search. https://www.youtube.com/results?search_query=remove+scuff+marks+from+paint+protection+film+My call would be to contact the provider (there are a couple) and ask them for a local fitter. They should be able to visit and quickly recondition it, if not just swap one panel. The factory does have a mobile fitter it uses who knows the tricks on the heavily curved Morgan shapes. He did the Coupe and made a lovely job of it. It may be that they can provide his details or sort it? I have a few scuffs on mine as I am no longer as flexible as I was and will just get it done in one hit.
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Hello HB Yeeeeesssssssssss
Does anyone on here know if the paint protector can be simply removed and replaced without needing a full paint job? I have sent an email to my usual dealers to ask for guidance as to who I should contact and await their reply. But I am ruddy chuffed to have driven her today.. HB Hello HB if there are no "cuts" in the paint protection I use a polishing mashine and some standart polish with very good result!
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
HB, I've had good success removing PPF scuffs with fine cutting paste followed by a good wax, as you would paintwork
If it needs replacing these chaps know Morgans (& have the patterns on file) and did a really good job of my Roadster
Covertech Midlands Ltd 01527 893712 enquiries@covertechmidlands.com
Posts: 148 Likes: 11
Posts: 148 Likes: 11 |
Return trip to Bicester Heritage for the Morgan Experience package that is "free" with a new CX car and what a great experience it was. Great place with really good people. Thoroughly enjoyed the track sessions and learnt a lot about how to drive quickly. Would recommend. Did 128 miles sunny miles there and back despite a weather forecast predicting biblical rain.
John R Marchant Plus Four JT10MOG "Florence"
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
JJR - I can echo that. I did the driving experience a few weeks ago in 30 degree heat. Really helped me to understand the driving dynamics and what car feels like as the back end pushes out under full throttle. Although never managed to really push the limits on the little chicane. Maybe hurtling at that block of brick wall on the inside of the first part was probably a step too far for my modest abilities. Was great fun though and loved the 1-1 experience. Thoroughly recommend it.
David
MY22 Plus Four, Alligator (AML Racing) Green ! đ
Posts: 1,360 Likes: 5
Posts: 1,360 Likes: 5 |
Thank you all for the various suggestions - all v reassuring. To be fair, the dealer came back to quite quickly last night and said if necessary they can resolve as they have someone coming over in a month to sort out another vehicle. They suggest in the meantime that I try heating the area with a hairdryer and that this may work quite effectively.. I shall give it a go and see whatâs whatâŚ. Best wishes and moggy hugs to all HB
Plus Four Bentley Velvet Red âGrandi Pâ Golf ehybrid thingy âToadieâ Polestar 4 âVgerâ
Posts: 206 Likes: 15
Posts: 206 Likes: 15 |
Peak District last week, blessed with good weather. ![[Linked Image]](https://i.ibb.co/D5dFqxc/IMG-2022-09-01-10-31-04-990.jpg)
Previous Mog Plus 4 Fiat Twin Cam. Plus Six
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
So do I gather you no longer have one on order  or is it a rental
You could have called in & had your nipples greased, oh it's a CX
This is it, second owner, waited 9 weeks for it to get the brakes done.
The dealer collected it today and took it back, information screen fault lights and a fair number of other issues, dealer has promised to fix them all.
i
