Topics49,841
Posts837,318
Posts: 101 Likes: 5
Posts: 101 Likes: 5 |
Afternoon all,
I noticed that the filler cap of my 2022 Plus Four was not always easy to open, almost from new. However, yesterday I stopped to fill up and it took me almost five minutes of fiddling to get the filler cap off.
What I noticed was that the lift and rotate tab when turned anti-clockwise should rotate the filler cap should. Mine is not rotating. Inspecting the filler at home, I see it is adjustable but will not touch it as it is under warranty.
Anyone else had this problem? If so, was it overcome by adjustment or replacement?
Thanks,
Andy
PS - tried to attach a photograph (302kB) but forum says 'too big'!!
Andy 2022 Plus Four / San Marino Blue
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Try some silicone grease Andy. Made a big difference to mine. Repeat when it stiffens up again.
Posts: 665 Likes: 31
Posts: 665 Likes: 31 |
I have the same problem , but they forgot to look at it when the car was at the garage for the brakes . They told me to add grease as above.
Posts: 101 Likes: 5
Thank you for both replies. A stupid question, but grease where? The outer plate should rotate with the tab and it doesn’t.
Please would you advise what should be greased. I have also considered converting to a Monza style filler cap but not sure how straight forward this is. Last thing I want is to be miles from anywhere needing fuel and find that I can’t open the filler cap!
Thanks in advance,
Andy
Posts: 181 |
The Monza cap used on the Le Mans CX cars is purely cosmetic the original cap is underneath.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
The Monza cap used on the Le Mans CX cars is purely cosmetic the original cap is underneath. As is the Monza cap on the Supersports Plus 8 ........ and every one has the same key number for the inner fuel cap lock....
I think the moving part under the cap has to be greased
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
Same problem for me when coming back from the Revival at the weekend. 5 minutes of fiddling around in the service station to get the cap off being careful not to bend or break the lift up lever which feels pretty flimsy. Real feeling of relief to be able to refuel!
I'll try and have a look one evening this week to see what/where can be greased.
At last on the CX though, I am not greasing suspension so I have got spare time to spread grease on the fuel cap :-).
Ian
A convert to the joy of Morgans after years of motorcycles
Posts: 101 Likes: 5
Posts: 101 Likes: 5
I agree, Almond. It is the flimsy nature of the pressed metal tab that worried me. I had visions of having to call out the breakdown services!
Your strap line chimes with me. I too have ridden motorcycles all my life (still do, TBH). It was driving a Morgan that I at last found a car with that delivered the same thrill as riding a motorcycle. I can add that I tried several performance cars on a track before making my decision. The German and Italian brands left me cold. Bet their filler caps work though!
