Topics49,897
Posts838,018
Posts: 101 Likes: 6
Posts: 101 Likes: 6 |
My Plus 8 has bonnet extenders on the back edge of the bonnet to allow greater airflow. Am I correct in thinking it is the original catch with a threaded hook on the outer edge, or a totally different catch than normal?. I have a photo onboard but don't know how to post as yet. Still getting to know the car. Any info would be appreciated. Happy Miles and kind regards.
Posts: 934 Likes: 12
Posts: 934 Likes: 12 |
Hello Kiwi 100 The original catch with a threaded hook on the outer edge are the only one I have seen. Stefan +8 +4 ARP4
Posts: 8,696 Likes: 416
Posts: 8,696 Likes: 416 |
These are the ones offered by Phoenix and attach to OE bonnet catch. ![[Linked Image]](http://www.morganhoods.com/sitebuildercontent/sitebuilderpictures/BonnExt003.jpg) Cain at Wolf Performance offers them as well but his website appears to be down at the moment!
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I have those Phoenix ones on my Plus8. The original catch onto the wing is drilled, the extenders bolted to them and adjusted. Measure twice, drill once where they are with swarf collected. You could remove them to drill but if careful then not a necessity. Make sure the bonnet pull mechanism is lubricated to make it easier to pull out the extra distance. Also periodically check the fixings to the wing of the original catch hook bracket as the extra strain/ vibration may loosen them. Allen key in the socket head above and small spanner on the nut underneath. Note, you will probably get people telling you the bonnet is not closed! Last week on the M6 ( stuck nearly 3 hours due to a closure) a couple of people warned me! It still gets quite warm under the bonnet but every little bit helps. I remove mine for the winter and replace for summer.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
These are the ones offered by Phoenix and attach to OE bonnet catch. ![[Linked Image]](http://www.morganhoods.com/sitebuildercontent/sitebuilderpictures/BonnExt003.jpg) Cain at Wolf Performance offers them as well but his website appears to be down at the moment! Michele is looking into the problem now, they didn't know it was down.
Posts: 939 Likes: 21
Posts: 939 Likes: 21 |
I have posted information previously, that I have taken over the manufacture of the Bonnet extensions from John at Phoenix. If anyone is interested send me a PM. Paul.
Wolf performance site now back up.
Posts: 101 Likes: 6
Yep, that makes sense. Thank you knowledgable chaps VERY much. I don't think they will be needed in NZ. Happy Miles and kind regards. Bryan.
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
Up where you are Bryan perhaps not -but if you are travelling through Auckland very much an advantage, as I learnt sitting in the carpark at Mog 18 you can tell a plus eight approaching without looking up as their fan is running hard.
99 plus 8 indigo
Posts: 5,461 Likes: 476
Posts: 5,461 Likes: 476 |
Up where you are Bryan perhaps not -but if you are travelling through Auckland very much an advantage, as I learnt sitting in the carpark at Mog 18 you can tell a plus eight approaching without looking up as their fan is running hard. Not all +8`s have their fans running for much of the time. I think it may be possible that when EFI lean burn fueling fueling was introduced to better suit emission reg requirements that there was more dependance on cooling fans than there is in my mid 80`s carb fed +8. I remember running in Front of Spanner Juggler in his then new +8 ( Circa 2002) on a Lakeland tour, when passing through town and stoped at either junctions or traffic lights, that his fan seemed to be constantly running. I also suspect many a Morgan may be fan dependant as the result of crud build up in the cooling system, lack of regular use can cause crud build up. Add to that the possibility of tuning mods where cooling might have not been considerd relative to the extra heat generated ..etc. etc..?
