0 members (), 350 guests, and 32 robots.
+8Rich 96
John V6 52
Topics49,897
Posts838,018
#755997 19/09/22 04:17 AM
kiwi100 Offline OP
My Plus 8 has bonnet extenders on the back edge of the bonnet to allow greater airflow. Am I correct in thinking it is the original catch with a threaded hook on the outer edge, or a totally different catch than normal?.
I have a photo onboard but don't know how to post as yet. Still getting to know the car. Any info would be appreciated.
Happy Miles and kind regards.
Hello Kiwi 100
The original catch with a threaded hook on the outer edge are the only one I have seen.
Stefan
+8
+4
ARP4
These are the ones offered by Phoenix and attach to OE bonnet catch.
Cain at Wolf Performance offers them as well but his website appears to be down at the moment!
I have those Phoenix ones on my Plus8. The original catch onto the wing is drilled, the extenders bolted to them and adjusted. Measure twice, drill once where they are with swarf collected. You could remove them to drill but if careful then not a necessity. Make sure the bonnet pull mechanism is lubricated to make it easier to pull out the extra distance. Also periodically check the fixings to the wing of the original catch hook bracket as the extra strain/ vibration may loosen them. Allen key in the socket head above and small spanner on the nut underneath.
Note, you will probably get people telling you the bonnet is not closed! Last week on the M6 ( stuck nearly 3 hours due to a closure) a couple of people warned me!
It still gets quite warm under the bonnet but every little bit helps. I remove mine for the winter and replace for summer.
Black Rat
Black Rat
Michele is looking into the problem now, they didn't know it was down.
Keith
2013 narrow bodied + 4 Ruby.
I have posted information previously, that I have taken over the manufacture of the Bonnet extensions from John at Phoenix. If anyone is interested send me a PM.
Paul.
Black Rat
Black Rat
Wolf performance site now back up.
Keith
kiwi100 Offline OP
Yep, that makes sense. Thank you knowledgable chaps VERY much.
I don't think they will be needed in NZ.
Bryan.
Up where you are Bryan perhaps not -but if you are travelling through Auckland very much an advantage, as I learnt sitting in the carpark at Mog 18 you can tell a plus eight approaching without looking up as their fan is running hard.
99 plus 8 indigo
Not all +8`s have their fans running for much of the time. I think it may be possible that when EFI lean burn fueling fueling was introduced to better suit emission reg requirements that there was more dependance on cooling fans than there is in my mid 80`s carb fed +8.
I remember running in Front of Spanner Juggler in his then new +8 ( Circa 2002) on a Lakeland tour, when passing through town and stoped at either junctions or traffic lights, that his fan seemed to be constantly running.
I also suspect many a Morgan may be fan dependant as the result of crud build up in the cooling system, lack of regular use can cause crud build up. Add to that the possibility of tuning mods where cooling might have not been considerd relative to the extra heat generated ..etc. etc..?
