Topics49,848
Posts837,407
Posts: 37,408 Likes: 977
Posts: 37,408 Likes: 977 |
Just one caution given that both Headley and G&W changed underwriters this year. Well worth checking a couple of weeks after renewal that your car shows as insured on the Motor Insurance Database. Could save you some time - check out askmid.com When I checked mine, it wasn't showing as insured. Hopefully, my phone call to the broker has gotten this corrected. Thanks Paul, having checked our three one was not on the Database so an email on the way to Headley/ERS.
Posts: 5,464 Likes: 171
Posts: 5,464 Likes: 171 |
Just one caution given that both Headley and G&W changed underwriters this year. Well worth checking a couple of weeks after renewal that your car shows as insured on the Motor Insurance Database. Could save you some time - check out askmid.com When I checked mine, it wasn't showing as insured. Hopefully, my phone call to the broker has gotten this corrected. Thanks Paul, having checked our three one was not on the Database so an email on the way to Headley/ERS. It could take up to 7 days to appear in the Database. In the interim, worth ensuring that you have a copy of the insurance certificate in the affected car. It could save you a lot of time if a keen eyed police officer checks the car out.
Just one caution given that both Headley and G&W changed underwriters this year. Well worth checking a couple of weeks after renewal that your car shows as insured on the Motor Insurance Database. Could save you some time - check out askmid.com When I checked mine, it wasn't showing as insured. Hopefully, my phone call to the broker has gotten this corrected. Thanks Paul, having checked our three one was not on the Database so an email on the way to Headley/ERS. It could take up to 7 days to appear in the Database. In the interim, worth ensuring that you have a copy of the insurance certificate in the affected car. It could save you a lot of time if a keen eyed police officer checks the car out. I'll do that thanks, the renewal was early August so it should be on there
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Thanks for the "heads up": pleased to see all ours are insured.
Posts: 1,079 Likes: 71
Posts: 1,079 Likes: 71 |
 Thanks Paul
David Aero S4
Posts: 141 Likes: 2
Posts: 141 Likes: 2 |
Gott and Wynn wanted £726 and a tracker ,they insured my Roadster for the past two years . Same underwriters as Heritage so it makes you wonder what’s going on . Gott & Wynne require a tracker if the car has an agreed value over £80,000. Although they use ERS as the underwriters, as to Heritage, the details of the policy are not quite the same. Although I didn't need to do so I fitted the Tracker recommended by Morgan (Global Telemetrics) and installed in all the CX cars. It works VERY well, as I found out early on when I forgot to press the button on the key card before driving. As soon as the car stopped moving i got a phone call. Another plus is that using the phone App whilst it was at Morgan I could see every movement, times, distance and maximum speed. Another plus is that it monitors battery voltage, given the car's past history this is important. Regarding Trackers Peter says he can see speeds car has travelled so my question is can the insurers use this against you if say you crashed and tracker says you were exceeding the speed limit  . I'm having to take out insurance next week and Headley as they've changed underwriters require a tracker for agreed values over £55k. Do any TM users have any other recommendations especially one's who don't require a tracker (which is a bit of a nonsense  since the chances of any Aero's being nicked is slim being so unique).
AnDrew G 2003 Aero S1 - past 2009 Aeromax - past 2012 +4 Supersport - past 2008 Aero S4 -past
