Topics49,841
Posts837,329
Posts: 338 Likes: 7
Posts: 338 Likes: 7 |
In Alaska every vehicle has a 110 volt plug sticking out of the grill. In winter you park, plug in and then go shop. It used to be free but I suppose now we are into Ev's they will find a reason to charge for the service.
'34 Family 4 '70 +8 '03 Hummer H2
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
My old Cooper 'S' 's carbs used to ice up every winter, strange phenomenon ....
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
When I was about 18 and driving a Sunbeam Rapier which had no garage I used to leave a small parafin lamp thing under the engine in winter. Anyone remember those? Yep, as my previous post Remember when folk used to tie a piece of cardboard over part of the front grille in winter ?
We even had a sort of shallow drum paraffin heater that you lit overnight and shoved under the engine
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I've still got a UFO paraffin heater in stock.
I've still got a UFO paraffin heater in stock. It's a Yorkshire thing, never chuck 'owt away, you never know when it will come in handy...sometime...
I've still got a UFO paraffin heater in stock. It's a Yorkshire thing, never chuck 'owt away, you never know when it will come in handy...sometime... Exactly!
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
My Ford Escort Mk2 with the 1.1 Kent engine suffered carb icing... even though you could point the air intake down to the exhaust manifold, likely the feeble heat from the 1.1 wasnt enough to stop the carb icing on motorway runs... but I haven't owned a car with a carb since 1991...
Posts: 938 Likes: 46
Posts: 938 Likes: 46 |
My 2cv had a kind of nose cover that I forgot one day in winter returning from Italy.... A a result even the idea of power was gone...
1973 2CV AK400 Ralley 1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
We had a grey plastic insert for our Ami 8 and without it you got zero heat from the heat exchangers either in the cockpit.
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
We even had a sort of shallow drum paraffin heater that you lit overnight and shoved under the engine Ahh..you caught me sleeping at the back!
