2 members (TBM, Bishmog),
262
86
Topics49,847
Posts837,389
Posts: 8 |
I,m thinking the same Heinz,perhaps thick sound deadening is the way to go! Also forgot to say that I love the car and am glad to be back in the Morgan community.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Grant, if you drive 160 km/h at 4000 revs in fifth gear you have a 3,7 final ratio. 4.1 should give around 145 km/h at 4000 rpm. And yes, I also love my 4/4 a lot.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Hi guys,thanks for all the input.This is where I am at the moment.I have had it confirmed that my 4/4 sport was converted to competition spec by Revolutions up in Perth who converted it to go racing.It has throttle bodies,LSD,roll bar,AVO,s,panhard rod,etc,etc.After listening to all your comments and talking to Revolutions my next course of action is to replace the medium priced diff oil I purchased(with friction modifier)for some very expensive(£215 for 2.5 litres)diff oil+friction modifier,as advised in gomog.I will give this a go and report back to you with the result.Revolutions have said that if this does not cure the "ringing howl"I can take it back to them for investigation. Grant, that oil price is ridiculous Try talking to the chaps at Millers oils, they have a good tech dept, personally I use this in LS diffs, https://www.millersoils.co.uk/products/crx-ls-75w140-nt-2/ the Nanotech stuff has some benefits that may help your situation
To be honest, I would also follow Cooperman's advice. You can always upgrade. But the cost of the oil you want to buy is higher than caviar. Better to try a reasonable but good oil and invest the 215 GBP in French or Italian wine.
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
No panic about BTR diffs in Australasia, they are as common as muck
99 plus 8 indigo
Also that which Morgan used, waikiore?
The shafts may differ in length , but the diff head is the same I believe, and Holdens till last year were very common. In fact they won their last Bathurst just yesterday. My laziest Sunday of the year -watching the 1000k from start to finish -even Zak Brown was there watching his team (they came second) rather than Suzuka and F1.
99 plus 8 indigo
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
Bathurst - how nice to see it mentioned! I had to settle for the BTCC events yesterday  I would go with Jon & Heinz suggestion Grant
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Hi guys,thanks for all the input.This is where I am at the moment.I have had it confirmed that my 4/4 sport was converted to competition spec by Revolutions up in Perth who converted it to go racing.It has throttle bodies,LSD,roll bar,AVO,s,panhard rod,etc,etc.After listening to all your comments and talking to Revolutions my next course of action is to replace the medium priced diff oil I purchased(with friction modifier)for some very expensive(£215 for 2.5 litres)diff oil+friction modifier,as advised in gomog.I will give this a go and report back to you with the result.Revolutions have said that if this does not cure the "ringing howl"I can take it back to them for investigation. Grant, that oil price is ridiculous Try talking to the chaps at Millers oils, they have a good tech dept, personally I use this in LS diffs, https://www.millersoils.co.uk/products/crx-ls-75w140-nt-2/ the Nanotech stuff has some benefits that may help your situation I agree with Jon about that ridiculous price. The best oil in the world will not hide the wailing from a badly adjusted or worn crown wheel and pinion, IF that is the issue. Having said that trying a premium oil such as Redline full synthetic 75W/90 LSD oil may be a relatively inexpensive fix if the problem is elswhere. Click image for source. ![[Linked Image]](https://i.ebayimg.com/images/g/yZQAAOSw2FVbSH-W/s-l1600.jpg) It cured the clicking I got when manoevering on full lock, suggesting the friction modifier works better than that in the factory supplied oil (assuming it included any). Note that I found my BTR axle required more than the handbook suggested (1.6 litres) so had to order a second bottle.
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
