Topics48,362
Posts813,325
Members9,215
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
Those switches can be a bit short lived..... The repeated arcing across the contacts degrades the switch. As time goes by you need more and more pressure to operate the switch so the brake lights become less responsive. No I don’t think the relay came as standard and yes adding a relay significantly reduces any contact arcing.
Roger 2011 Plus 4
Posts: 502 |
Thanks Rog, mystery solved 😁
2004 Series 1 Roadster
Posts: 7,910 Likes: 242
Posts: 7,910 Likes: 242 |
Roadsters of that era left the factory with the old style hydraulic pressure switch, these tended to fail because of the crap quality of switches (not MMC's fault almost all the current makes are rubbish) the longest lasting I've found are Intermotor brand.
Lot's of owners added a simple relay to reduce the load the switch contacts take & this generally works well, but worth carrying a spare hydraulic sw if you're doing long tours, as they can be changed roadside without needing to bleed the brakes if you are confident & don't dawdle with the spanner
Posts: 502 |
Lot's of owners added a simple relay to reduce the load the switch contacts take & this generally works well, but worth carrying a spare hydraulic sw if you're doing long tours, as they can be changed roadside without needing to bleed the brakes if you are confident & don't dawdle with the spanner Mine was replaced a couple of years ago cos the previous owner replaced it with a one that didn't have a tapered thread, and this apparently cracked the union. Guess I'd better get a spare.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Fit a relay and a microswitch on the pedal. It's a simple mod and solves the problem.
Posts: 7,940 Likes: 218
Posts: 7,940 Likes: 218 |
Lot's of owners added a simple relay to reduce the load the switch contacts take & this generally works well, but worth carrying a spare hydraulic sw if you're doing long tours, as they can be changed roadside without needing to bleed the brakes if you are confident & don't dawdle with the spanner Relays have their place but would favour a quality hydraulic or direct pedal operated switch, underrated current wise for the task. The extra wiring and possibly poor location of relay adds complexity and potential unreliability. Note also having LED brake lights as well as generally being brighter puts far less current load on switch.
Posts: 502 |
Lot's of owners added a simple relay to reduce the load the switch contacts take & this generally works well, but worth carrying a spare hydraulic sw if you're doing long tours, as they can be changed roadside without needing to bleed the brakes if you are confident & don't dawdle with the spanner Relays have their place but would favour a quality hydraulic or direct pedal operated switch, underrated current wise for the task. The extra wiring and possibly poor location of relay adds complexity and potential unreliability. Note also having LED brake lights as well as generally being brighter puts far less current load on switch. I'm not that confident in wiring in a microswitch. I take it from what you say that there's no reason why I can't just swap my bulbs for led ones?
Posts: 502 |
Just ordered 3 replacement led bulbs from classic car leds. Bet they outlast the car 😂
Fit a relay and a microswitch on the pedal. It's a simple mod and solves the problem. Yes, I went down that route eventually, if you fit a decent plunger switch rated at least 5 amps you don't even need the complexity of a relay
