5 members (CooperMan, JMcL, Arwyn Williams, +8Rich, JohnHarris), 309 guests, and 66 robots.
+8Rich 99
Topics49,835
Posts837,258
#758262 15/10/22 03:34 PM
ChrisM Offline OP
I wonder if anyone can help with my 1998 4/4 blowing the fuel pump fuse on startup. It doesn’t happen all the time, but often enough to be annoying. It’s fitted with a 15 amp fuse, is this the correct size? Once running the car runs perfectly.
Thanks, Chris
Fuse box info here from GoMog Fuses
Intermittent fail could be a fuel pump on the way out
15 amp fusing sounds right for a fuel pump Chris. If it's blowing then excessive load on pump itself due to dirt or simply as John suggests pump is on its way out. Can't say definitively as 1998 wiring diagrams where available are a bit hit and miss but there doesn't appear to be a fuel pump relay. Doubt if such would be the cause anyway.
PJC Offline
You could try a full dose of Seafoam in a full tank of fuel which will clean and lubricate the whole fuel system so if it the fuel pump which is a bit bunged up this could work. You can get Seafoam on Amazon - great stuff been using it for years and use a small dose permanently in my older motorcycles.
Cheers, Paul
Never heard of Seafoam before.
But just ordered off eBay…seems well worth a go!
Thanks for posting.
Neil
NeilL #758371 16/10/22 08:31 PM
TBM Offline
Thanks for posting.
Used it on several bikes with some success. Very popular stateside and now commonly available in the UK.
